When the USB port of EC200T device is connected to a Linux PC ( running ubuntu) … we first see that a Marvell device with Vendor ID = 1286 and Product ID = 821A is detected ( output of lsusb command) … almost within few seconds it diappears and one of the two below things happen
a) Marvell device diappears and another device with Vendor ID= 2c7c and Product ID = 6026 appears ( again output of lsusb command is used to check USB connected devices)
b) Marvell device diappears and no other device appears in its place
When the case b) happens we can not proceed further since the Quectel EC200T device is not detected , hence we can not pass on AT command to module over USB port
can you help explain - why above may be happening ? We have already mass produced around 1800 EC200T based USB dongle - which worked well for us … but recently on about a 100 devices we are facing above issue.
Can you help resolve this ?
Regards
Jitender
Further i am attaching the bootup logs for both Working and Non working boards.
Also note that after putting the EC200T in download mode we are able to download the EC200TCNHAR05A03M16 version of software … but still the non working boards do not come up normallyworking_board_logs_ec200t_dongle.zip (3.6 KB) non_working_debug_uart_logs_ec200t.zip (839 Bytes)
