I’m looking for EC200CN drivers for Raspberry Pi 3B+. Tried searching on website and forums but somehow can’t find them. Can you please share the drivers?
Thank you in advanced.
Can someone please help here?
Thank you
Regards,
Vaibhav
What driver(s) are you looking for?
What’s wrong with the standard OS drivers?
Hey, sorry for late reply, was away due to holidays.
Thank you your response, sharing all information below -
Setup
EC200 is connected to raspberry pi over USB.
Issue 1
pi@autodrive6:~ $ ls /dev/ttyU*
ls: cannot access '/dev/ttyU’: No such file or directory*
I’m sure the hardware connection is correct, as I can send/receive AT commands over /dev/ttyS0.
pi@autodrive6:~ $ usb-devices
T: Bus=01 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 3 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=ff(vend.) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=0424 ProdID=ec00 Rev=02.00
C: #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=2mA
I: If#=0x0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=ff Driver=smsc95xx
Also I could not find the PID and VID for EC200 in the document “Quectel_LTE&5G_Linux_USB_Driver_User_Guide_V2.0.pdf”.
Can you please help me see 4 USB tty devices with EC200?
Extra Information
If I temporarily use EC25 (as EC200 is not working)*
Module Info (ATI) → Quectel, EC25, Revision: EC25EFAR06A08M4G
All USB devices are working correctly
ls /dev/ttyU*
/dev/ttyUSB0 /dev/ttyUSB1 /dev/ttyUSB2 /dev/ttyUSB3
Also modified the kernel as per the instructions from “Quectel_LTE&5G_Linux_USB_Driver_User_Guide_V2.0.pdf” and GobiNet driver works correctly.
Issue is faced only with EC200 but working correctly with EC25. Please help!!!
Happy new year to you all ![]()
Please show the output of cat /sys/kernel/debug/usb/devices
Here’s the output from the given command -
sudo cat /sys/kernel/debug/usb/devices
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
B: Alloc= 0/800 us ( 0%), #Int=-554, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev= 5.10
S: Manufacturer=Linux 5.10.110-v7+ dwc_otg_hcd
S: Product=DWC OTG Controller
S: SerialNumber=3f980000.usb
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 5
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=02 MxPS=64 #Cfgs= 1
P: Vendor=0424 ProdID=9514 Rev= 2.00
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 2mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=01 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 1 Ivl=256ms
I:* If#= 0 Alt= 1 #EPs= 1 Cls=09(hub ) Sub=00 Prot=02 Driver=hub
P: Vendor=0424 ProdID=ec00 Rev= 2.00
I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=ff Driver=smsc95xx
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=83(I) Atr=03(Int.) MxPS= 16 Ivl=1ms
It shows that the modem is not connected to the USB bus.
I think modem is connected, I can see a new device created /dev/ttyS0 which is responding to AT commands
I’m getting the following output for ATI -
[20:32:29:182] ATI␍␍␊
[20:32:29:182] Quectel␍␊
[20:32:29:182] EC200U␍␊
[20:32:29:182] Revision: EC200UCNAAR02A09M08␍␊
[20:32:29:182] ␍␊
[20:32:29:182] OK␍␊
The output you provided earlier shows that the modem is not connected to the USB bus.
I can assume that you somehow connected to the UART interface of the modem.
Verified the continuity with multi-meter, seems to be correct. Just to rule out any driver issue, can you please share the EC200U-CN drivers for Kernel - 5.10?
At least let me know the product and vendor id for EC200U-CN.
Thank you in advance!
You don’t have any interface with a driver missing.
Until you see 2c7c:0901 in USB devices you don’t need to worry about the driver.
Hello jfrog,
I found and fixed issue with USB connection, now I see 2c7c:0901 in USB devices.
Here’s the output of - sudo cat /sys/kernel/debug/usb/devices
B: Alloc= 0/800 us ( 0%), #Int=-1301, #Iso= 0
T: Bus=01 Lev=02 Prnt=02 Port=02 Cnt=02 Dev#= 4 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=2c7c ProdID=0901 Rev= 3.18
S: Manufacturer=Android
S: Product=Android
C:* #Ifs= 9 Cfg#= 1 Atr=e0 MxPwr=400mA
A: FirstIf#= 0 IfCount= 2 Cls=02(comm.) Sub=06 Prot=00
I:* If#= 0 Alt= 0 #EPs= 1 Cls=02(comm.) Sub=06 Prot=00 Driver=cdc_ether
E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=32ms
I: If#= 1 Alt= 0 #EPs= 0 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_ether
I:* If#= 1 Alt= 1 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_ether
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=83(I) Atr=03(Int.) MxPS= 512 Ivl=4096ms
I:* If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 4 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 5 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=87(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 6 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=88(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 7 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=8a(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=07(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=89(I) Atr=03(Int.) MxPS= 512 Ivl=4096ms
I:* If#= 8 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=8b(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=08(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
T: Bus=01 Lev=02 Prnt=02 Port=04 Cnt=03 Dev#= 5 Spd=1.5 MxCh= 0
D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=1a2c ProdID=2d23 Rev= 1.10
S: Manufacturer=USB
S: Product=USB Keyboard
C:* #Ifs= 2 Cfg#= 1 Atr=a0 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=01 Prot=01 Driver=usbhid
E: Ad=81(I) Atr=03(Int.) MxPS= 8 Ivl=10ms
I:* If#= 1 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=00 Prot=00 Driver=usbhid
E: Ad=82(I) Atr=03(Int.) MxPS= 8 Ivl=10ms
However I still don’t see any USB devices in /dev/tty.
Below is the output for - ls /dev/tty*
/dev/tty /dev/tty12 /dev/tty17 /dev/tty21 /dev/tty26 /dev/tty30 /dev/tty35 /dev/tty4 /dev/tty44 /dev/tty49 /dev/tty53 /dev/tty58 /dev/tty62 /dev/ttyAMA0
/dev/tty0 /dev/tty13 /dev/tty18 /dev/tty22 /dev/tty27 /dev/tty31 /dev/tty36 /dev/tty40 /dev/tty45 /dev/tty5 /dev/tty54 /dev/tty59 /dev/tty63 /dev/ttyprintk
/dev/tty1 /dev/tty14 /dev/tty19 /dev/tty23 /dev/tty28 /dev/tty32 /dev/tty37 /dev/tty41 /dev/tty46 /dev/tty50 /dev/tty55 /dev/tty6 /dev/tty7 /dev/ttyS0
/dev/tty10 /dev/tty15 /dev/tty2 /dev/tty24 /dev/tty29 /dev/tty33 /dev/tty38 /dev/tty42 /dev/tty47 /dev/tty51 /dev/tty56 /dev/tty60 /dev/tty8
/dev/tty11 /dev/tty16 /dev/tty20 /dev/tty25 /dev/tty3 /dev/tty34 /dev/tty39 /dev/tty43 /dev/tty48 /dev/tty52 /dev/tty57 /dev/tty61 /dev/tty9
How to proceed from here?
Thank you so much for your support ![]()
Regards,
Vaibhav
run as root:
modprobe option
echo "2c7c 0901" > /sys/bus/usb-serial/drivers/option1/new_id
Thank you! Now I see 6 USB devices
ls /dev/ttyU*
/dev/ttyUSB0 /dev/ttyUSB1 /dev/ttyUSB2 /dev/ttyUSB3 /dev/ttyUSB4 /dev/ttyUSB5 /dev/ttyUSB6
However I can’t see the NMEA messages on /dev/ttyUSB2. BTW, what is CME Error: 58?
Also how to load GobiNet driver?
I do not see +CME ERROR: 58 mentioned in the manual, so I will leave this question to someone else.
I’m not sure that /dev/ttyUSB2 ( If#= 4) is the right port for NMEA messages and I suggest to check URC configuration with AT+QURCCFG="urcport"
I have reasons to believe that the highest numbered port ( If#= 8) is the one that is used for NMEA.
I see no need for GobiNet driver, please clarify why you think you need it.
