Module: EC200A-EL
Firmware (ATI): EC200AELLAR01A05M16_TP
Platform: ASR1803 / FALCON (LWG)
I’m trying to use USSD on an EC200A-EL module (it’s built into a consumer LTE
router I own) and it does not work on this firmware.
Symptom: the module accepts the request but no network +CUSD: response is
ever delivered to the AT interface:
AT+CUSD=1,"*120#",15
+CME ERROR: 4
Dialling the USSD string as a supplementary-service call is accepted, but also
yields no response:
ATD*120#;
(no +CUSD: URC ever arrives; waited >30s, +CUSD=1 reporting on, CMEE=2)
The module is otherwise fully healthy on this SIM/network:
+CGATT: 1 (data works)
+COPS: 0,2,"<plmn>",7 (registered, LTE)
+CIREG: 1,1,15 (IMS registered, UT-capable)
Why I think this is a firmware-branch issue, not a hardware limitation:
There is a published user report for EC200AAUHAR01A15M16_01.200.01.200
(EC200A-AU, 01.200 branch) where USSD works end-to-end; a real asynchronous
+CUSD: is returned over the AT port:
+CUSD: 2,"4D534953444E203A2033303435353438303135",244
(the payload is hex-encoded ASCII: “MSISDN : 3045548015”). So the ASR/Falcon
platform clearly can do USSD on the 01.200 branch.
By contrast, the builds I can find on the 01.001 branch, my own
EC200AELLAR01A05M16_TP, and e.g. EC200AEUHAR01A05M16, all show the same
“accepted, but no +CUSD:” behaviour.
My questions:
Which EC200A-EL firmware build has working USSD, a mobile-originated
AT+CUSDthat returns the network’s+CUSD:response, equivalent to the
fix in EC200AAUHAR01A15M16_01.200.01.200? Could you provide that EL build? -
In what format is that EL package delivered, a full raw image (.blf / .bin),
or only a DFOTA delta package? I’d prefer a full raw image rather than a
delta. What is the exact package filename? -
If possible, could you provide two adjacent EL builds, the last one with
the broken USSD and the first one with the fix (full raw images)? That would
let me confirm the fix by direct comparison before updating. -
In which EC200A-EL build number was USSD first fixed? (release notes /
change ID, if available) -
For the build you suggest: does the firmware implement UE-originated USSD
over CS and/or USSI (3GPP TS 24.390), withAT+CUSDwired to it and+CUSD:
URC delivery, and is the+CUSD:payload returned hex-encoded (as in the
AU log above)? -
(Secondary) What flashing tool (QFlash / QDloader, with version) and ASR USB
driver match this build, in case I flash the module directly?
This is for personal use on my own module. I’m happy to provide the full ATI
output or any other details. Thanks very much for any help.
