EC200A download tool for Linux
I have an eval board for EC200A. Now I would like to flash the device from my Linux desktop. I do not have Windows, and do all my development from Linux.
has any solution under Linux to upload firmware?
As I know exist QFirehose tool for it but firmware for QFlash does not applicable for it (archive should has “recover/firehose” folder).
manual for QFirehose - How to upgrade module thru Linux QFirehose - #8 by venkatms
thread about retriving firmware in QFlash format - EC200A-EU latest firmware - #6 by herbert.pan-Q
I`m interesting too.
mohammad_mazarei, could you share your solution, if have?
thank you for your replay, but It’s not work for me, I think firehose protocol for Qualcomm SOC, but I use ASR version of EC200A,
my modem partnumber is EC200A-EUAB
pls try QDloader_Linux_Android_V1.0.11,I have sent it to you
thank you, when try to use that I got error:
[000:000] Version: QDloader_Linux_Android_V1.0.11
[000:000] mcu is little endian
[000:000] scan quectel modem
/sys/bus/usb/devices/2-3 2ecc/3002/0
open(/dev/bus/usb/002/050) = 4
Segmentation fault
I use debian 12, modem is in boot loader and system detected that:
Bus 002 Device 050: ID 2ecc:3002 ASR Microelectronics FALCON
and I ran QDloader with this parameter
QDloader -f EC200AEUABR02A02M2G_OCPU/update/quectel_skylark_pm802_standard_AB_2G.blf
Hi, could you send QDloader too?
you can download from this post
ec200u-quecopen-on-linux
@herbert.pan-Q how can use QDloader tools ?
You need the FBFMake to generate the image for upgrade.
FBFMake.exe -r Falcon_EVB_QSPI_Nor_LWG_Only_Nontrusted_PM802_LPDDR2.blf -f out
Then the Binfile.bin will be in the out directory.
Hi!
Could you send me FBFMake.exe too?
Sent already
Please check your email
Hi all,
Do you have FOTA server with EC200 firmware Updates?
This is cool feature - https://auroraevernet.ru/upload/iblock/cb0/cb07e8957ba2a06c99a46a76bab8bb0a.pdf
Hi, Could you send me FBFMake.exe?
I will send it via email.
It is Windows format tool
maybe can I run with wine on Linux
I need QDLoader for Linux too. Can I have download link?
