We purchased a Quectel UMTS<E-EVB-B evaluation board with an EC200A-AUAB module for laboratory activities and student projects in our Mobile Communications course at Universidad Nacional de la Patagonia San Juan Bosco (UNPSJB), Argentina.
Our module reports:
ATI
EC200A-AUAB
Revision: EC200AAUABR02A05M2G_OCPU
Our goal is to test LTE data communication with a server using TCP/IP and MQTT, initially from the evaluation board and later interfacing an external microcontroller through UART.
The current firmware does not list the usual TCP/IP socket or MQTT AT commands. Your support team confirmed that EC200AAUAB only supports QuecOpen, cannot switch to standard AT firmware, and already has the latest available firmware.
Therefore, could you please provide the resources needed to evaluate the module using QuecOpen?
Specifically, we may need:
The SDK and libraries compatible with this exact AUAB variant and firmware.
The required compiler/toolchain and development environment.
A getting-started guide for compiling, flashing, running, and debugging applications.
Compatible flashing tools, USB drivers, and recovery instructions.
API documentation and working examples for network registration, APN/data connection setup, TCP/UDP sockets, and MQTT publishing/subscribing.
UART examples to exchange data with an external microcontroller.
Please confirm whether the SDK includes an MQTT client library and which UART is accessible through the EVB RS-232 connector.
If QuecPython is supported on this exact AUAB variant, please provide the compatible firmware and instructions as an alternative.
This is an educational project, with no planned mass production. If SDK access requires an NDA or a university evaluation request, please explain the procedure and direct us to the appropriate contact.
Thank you for helping us put this evaluation kit into use.
