Hello guys,
I am using module EC200A and connect to my PC Ubuntu 20.4. My PC recognizes it cdc_ethernet, you can see from dmesg:
[ 6141.331842] usb 1-12: new high-speed USB device number 19 using xhci_hcd
[ 6141.480532] usb 1-12: New USB device found, idVendor=2c7c, idProduct=6005, bcdDevice= 3.18
[ 6141.480533] usb 1-12: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6141.480534] usb 1-12: Product: Android
[ 6141.480534] usb 1-12: Manufacturer: Android
[ 6141.480535] usb 1-12: SerialNumber: 0000
[ 6141.485347] cdc_ether 1-12:1.0 usb0: register ‘cdc_ether’ at usb-0000:00:14.0-12, CDC Ethernet Device, 02:0c:29:a3:9b:6d
[ 6141.495624] cdc_ether 1-12:1.0 enp0s20f0u12: renamed from usb0
lsusb also shows modem:
Bus 001 Device 023: ID 2c7c:6005
However there are no /dev/ttyUSB* files, so I cannot use it.
How can I switch to usb modern mode to have /dev/ttyUSB* and send AT command to it.
I have used this module on another linux Embedded board and it works great but when i plug it into my PC it’s like this.
Thanks for your help.
I have the exact same output for /sys/kernel/debug/usb/devices but i dont have usb-serial folder (option) so i cant run the “echo “2c7c 6005” > /sys/bus/usb-serial/drivers/option1/new_id”. I think i dont have any driver running, it’s a plain Debian 12.
Can you send me the driver?
Is it necessary to use ttyUSB to use the modem, or is cdc ether sufficient?
