The RX diversity mode is enabled by default on the EC200 module. Is there an AT command to turn it off?
What will the effect be if the RX diversity mode is on yet there is no RX diversity antenna connected on the module? The pin is of course routed to the antenna connector.
Hi ,
You don’t need to disable the RX diversity and it doesn’t have any effect on your system when you are not using,Using RX diversity antenna can increase the receiving sensitivity, it is recommend to add RX diversity antenna when conditions permit.
