Dear Sir or Madam
I bought an EC20 mini PCIe with EC20EQAR02A05E2G part number. I also setup Quectel USB Drivers For UC20&UC15&EC20_V1.1 driver in my system which operate with window 7 32bit system.
Then I made a dial up connection in order to connect to the Internet which was successfully work and connect the system to the Internet. But when I restart the Windows 7 or switch the user dial up connection stuck in dial up step and module can not registered in the network return Dial-up Connection Error 777 – The connection attempt failed because the modem (or other connecting device) on the remote computer is out of order.
windows dial up log is come below:
C:\Windows\tracing\Explorer_RASAPI32.LOG
[3824] 03-30 15:22:48:825: DwEnumEntryDetails
[3824] 03-30 15:22:48:825: IsRasmanServiceRunning=1
[3824] 03-30 15:22:48:825: ReadPhonebookFileEx: called for pbk C:\ProgramData\Microsoft\Network\Connections\Pbk\rasphone.pbk, flags 8
[3824] 03-30 15:22:48:825: IsPublicPhonebook=1
[3824] 03-30 15:22:48:825: path=C:\ProgramData\Microsoft\Network\Connections\Pbk\rasphone.pbk
[3824] 03-30 15:22:48:825: full path=C:\ProgramData\Microsoft\Network\Connections\Pbk\rasphone.pbk
[3824] 03-30 15:22:48:825: IsVirtualizationNeeded: return value = 1
[3824] 03-30 15:22:48:825: GetLUAPhonebookPath: Return value 0 hiddenpbk path C:\Users\atm\AppData\Roaming\Microsoft\Network\Connections\Pbk_hiddenPbk\rasphone.pbk
[3824] 03-30 15:22:48:825: ReadRasFile: ReadEntryList returned 0
[3824] 03-30 15:22:48:825: SyncMasterPhonebookFile:++
[3824] 03-30 15:22:48:825: FindFirstFile failed with 0x3
[3824] 03-30 15:22:48:825: ReadRasFile: File C:\ProgramData\Microsoft\Network\Connections\Pbk\rasphone.pbk does not exist
[3824] 03-30 15:22:48:825: DeleteEntriesOnlyInHiddenPhonebookFile ++
[3824] 03-30 15:22:48:825: WritePhonebookFile
[3824] 03-30 15:22:48:825: ModifyEntryList: Number of connections written 0
[3824] 03-30 15:22:48:825: RASSQM: In WritePhonebookFile Number of alluser profiles set 0
[3824] 03-30 15:22:48:825: DeleteEntriesOnlyInHiddenPhonebookFile : WritePhonebookFile failed with 0
[3824] 03-30 15:22:48:825: RASSQM: In ReadPhonebookFile Number of alluser profiles set 0
[3824] 03-30 15:22:48:825: ReadPhonebookFile returns 0
[3824] 03-30 15:22:48:825: ReadPhonebookFileEx: called for pbk C:\Users\atm\AppData\Roaming\Microsoft\Network\Connections\Pbk\rasphone.pbk, flags 8
[3824] 03-30 15:22:48:825: IsPublicPhonebook=0
[3824] 03-30 15:22:48:825: path=C:\Users\atm\AppData\Roaming\Microsoft\Network\Connections\Pbk\rasphone.pbk
[3824] 03-30 15:22:48:825: full path=C:\Users\atm\AppData\Roaming\Microsoft\Network\Connections\Pbk\rasphone.pbk
[3824] 03-30 15:22:48:825: IsVirtualizationNeeded: return value = 0
[3824] 03-30 15:22:48:825: ENTRY: Reading “Dial-up Connection”
Before LoadPortsList2 in ReadEntryList()
[3824] 03-30 15:22:48:825: LoadPortsList2
[3824] 03-30 15:22:48:825: GetRasPorts
[3824] 03-30 15:22:48:825: RasPortEnum…
[3824] 03-30 15:22:48:825: RasPortEnum=603,c=10
[3824] 03-30 15:22:48:825: RasPortEnum=0,c=10
[3824] 03-30 15:22:48:825: RasGetDevConfig
[3824] 03-30 15:22:48:841: RasGetDevConfig=603
[3824] 03-30 15:22:48:841: RasGetDevConfig=0
[3824] 03-30 15:22:48:841: SanitizeUnimodemBlob: mdm prot=0
[3824] 03-30 15:22:48:841: Port=COM10,fHw=0,fEc=0,bps=115200,fSp=1,prot=0
[3824] 03-30 15:22:48:841: StringCchCopy failed due to error 0x8007007a
[3824] 03-30 15:22:48:841: LoadPortsList=0
[3824] 03-30 15:22:48:841: successfully finished LoadPortsList2 in ReadEntryList()
[3824] 03-30 15:22:48:841: Reading media group “serial”
[3824] 03-30 15:22:48:841: New link format
DUPTEST:Port in this media
Trying to match the phonebook port in the system ports
[3824] 03-30 15:22:48:841: Port configured
[3824] 03-30 15:22:48:841: SetDefaultModemSettings(bps=115200)=1
[3824] 03-30 15:22:48:841: Reading device group “modem”
[3824] 03-30 15:22:48:841: Device List after deleting dupe
[3824] 03-30 15:22:48:841: ReadRasFile: ReadEntryList returned 0
[3824] 03-30 15:22:48:841: RASSQM: In ReadPhonebookFile Number of myuse profiles set 1
[3824] 03-30 15:22:48:841: ReadPhonebookFile returns 0
[3824] 03-30 15:22:48:841: RasGetAutodialAddressW
[3824] 03-30 15:22:48:841: DwEnumEntryDetails done. 0
[3824] 03-30 15:22:48:841: RasGetEntryHrasconn
[3824] 03-30 15:22:48:841: IsRasmanServiceRunning=1
[3824] 03-30 15:22:48:856: RasGetCredentialsW
[3824] 03-30 15:22:48:856: IsRasmanServiceRunning=1
[3824] 03-30 15:22:48:856: GetPbkAndEntryName
[3824] 03-30 15:22:48:856: ReadPhonebookFileEx: called for pbk C:\Users\atm\AppData\Roaming\Microsoft\Network\Connections\Pbk\rasphone.pbk, flags 8
[3824] 03-30 15:22:48:856: IsPublicPhonebook=0
[3824] 03-30 15:22:48:856: path=C:\Users\atm\AppData\Roaming\Microsoft\Network\Connections\Pbk\rasphone.pbk
[3824] 03-30 15:22:48:856: full path=C:\Users\atm\AppData\Roaming\Microsoft\Network\Connections\Pbk\rasphone.pbk
[3824] 03-30 15:22:48:856: IsVirtualizationNeeded: return value = 0
[3824] 03-30 15:22:48:856: ENTRY: Reading “Dial-up Connection”
[3824] 03-30 15:22:48:856: LoadPortsList2
[3824] 03-30 15:22:48:856: GetRasPorts
[3824] 03-30 15:22:48:856: RasPortEnum…
[3824] 03-30 15:22:48:856: RasPortEnum=603,c=10
[3824] 03-30 15:22:48:856: RasPortEnum=0,c=10
[3824] 03-30 15:22:48:856: RasGetDevConfig
[3824] 03-30 15:22:48:856: RasGetDevConfig=603
[3824] 03-30 15:22:48:856: RasGetDevConfig=0
[3824] 03-30 15:22:48:856: SanitizeUnimodemBlob: mdm prot=0
[3824] 03-30 15:22:48:856: Port=COM10,fHw=0,fEc=0,bps=115200,fSp=1,prot=0
[3824] 03-30 15:22:48:856: StringCchCopy failed due to error 0x8007007a
[3824] 03-30 15:22:48:856: LoadPortsList=0
[3824] 03-30 15:22:48:856: successfully finished LoadPortsList2 in ReadEntryList()
[3824] 03-30 15:22:48:856: Reading media group “serial”
[3824] 03-30 15:22:48:856: New link format
[3824] 03-30 15:22:48:856: Port configured
[3824] 03-30 15:22:48:856: SetDefaultModemSettings(bps=115200)=1
[3824] 03-30 15:22:48:856: Reading device group “modem”
[3824] 03-30 15:22:48:856: Device List after deleting dupe
[3824] 03-30 15:22:48:856: ReadRasFile: ReadEntryList returned 0
[3824] 03-30 15:22:48:856: RASSQM: In ReadPhonebookFile Number of myuse profiles set 1
[3824] 03-30 15:22:48:856: ReadPhonebookFile returns 0
[3824] 03-30 15:22:48:856: DuplicatePhoneNode
[3824] 03-30 15:22:48:856: GetPbkAndEntryName. rc=0x0
[3824] 03-30 15:22:48:872: ENTRY: Reading “Dial-up Connection”
[3824] 03-30 15:22:48:872: LoadPortsList2
[3824] 03-30 15:22:48:872: GetRasPorts
[3824] 03-30 15:22:48:872: RasPortEnum…
[3824] 03-30 15:22:48:872: RasPortEnum=603,c=10
[3824] 03-30 15:22:48:872: RasPortEnum=0,c=10
[3824] 03-30 15:22:48:872: RasGetDevConfig
[3824] 03-30 15:22:48:872: RasGetDevConfig=603
[3824] 03-30 15:22:48:872: RasGetDevConfig=0
[3824] 03-30 15:22:48:872: SanitizeUnimodemBlob: mdm prot=0
[3824] 03-30 15:22:48:872: Port=COM10,fHw=0,fEc=0,bps=115200,fSp=1,prot=0
[3824] 03-30 15:22:48:872: StringCchCopy failed due to error 0x8007007a
[3824] 03-30 15:22:48:872: LoadPortsList=0
[3824] 03-30 15:22:48:872: successfully finished LoadPortsList2 in ReadEntryList()
[3824] 03-30 15:22:48:872: Reading media group “serial”
[3824] 03-30 15:22:48:872: New link format
[3824] 03-30 15:22:48:872: Port configured
[3824] 03-30 15:22:48:872: SetDefaultModemSettings(bps=115200)=1
[3824] 03-30 15:22:48:872: Reading device group “modem”
[3824] 03-30 15:22:48:872: Device List after deleting dupe
[3824] 03-30 15:22:48:872: ReadRasFile: ReadEntryList returned 0
[3824] 03-30 15:22:48:872: RASSQM: In ReadPhonebookFile Number of myuse profiles set 1
[3824] 03-30 15:22:48:872: ReadPhonebookFile returns 0
[3824] 03-30 15:22:48:872: DuplicatePhoneNode
[3824] 03-30 15:22:48:872: GetPbkAndEntryName. rc=0x0
[3824] 03-30 15:22:50:135: RasSetCredentialsW
[3824] 03-30 15:22:50:135: IsRasmanServiceRunning=1
[3824] 03-30 15:22:50:135: GetPbkAndEntryName
[3824] 03-30 15:22:50:135: ReadPhonebookFileEx: called for pbk C:\Users\atm\AppData\Roaming\Microsoft\Network\Connections\Pbk\rasphone.pbk, flags 0
[3824] 03-30 15:22:50:135: IsPublicPhonebook=0
[3824] 03-30 15:22:50:135: path=C:\Users\atm\AppData\Roaming\Microsoft\Network\Connections\Pbk\rasphone.pbk
[3824] 03-30 15:22:50:135: full path=C:\Users\atm\AppData\Roaming\Microsoft\Network\Connections\Pbk\rasphone.pbk
[3824] 03-30 15:22:50:135: IsVirtualizationNeeded: return value = 0
[3824] 03-30 15:22:50:135: ENTRY: Reading “Dial-up Connection”
[3824] 03-30 15:22:50:135: LoadPortsList2
[3824] 03-30 15:22:50:135: GetRasPorts
[3824] 03-30 15:22:50:135: RasPortEnum…
[3824] 03-30 15:22:50:135: RasPortEnum=603,c=10
[3824] 03-30 15:22:50:135: RasPortEnum=0,c=10
[3824] 03-30 15:22:50:135: RasGetDevConfig
[3824] 03-30 15:22:50:151: RasGetDevConfig=603
[3824] 03-30 15:22:50:151: RasGetDevConfig=0
[3824] 03-30 15:22:50:151: SanitizeUnimodemBlob: mdm prot=0
[3824] 03-30 15:22:50:151: Port=COM10,fHw=0,fEc=0,bps=115200,fSp=1,prot=0
[3824] 03-30 15:22:50:151: StringCchCopy failed due to error 0x8007007a
[3824] 03-30 15:22:50:151: LoadPortsList=0
[3824] 03-30 15:22:50:151: successfully finished LoadPortsList2 in ReadEntryList()
[3824] 03-30 15:22:50:151: Reading media group “serial”
[3824] 03-30 15:22:50:151: New link format
[3824] 03-30 15:22:50:151: Port configured
[3824] 03-30 15:22:50:151: SetDefaultModemSettings(bps=115200)=1
[3824] 03-30 15:22:50:151: Reading device group “modem”
[3824] 03-30 15:22:50:151: Device List after deleting dupe
[3824] 03-30 15:22:50:151: ReadRasFile: ReadEntryList returned 0
[3824] 03-30 15:22:50:151: RASSQM: In ReadPhonebookFile Number of myuse profiles set 1
[3824] 03-30 15:22:50:151: ReadPhonebookFile returns 0
[3824] 03-30 15:22:50:151: GetPbkAndEntryName. rc=0x0
[3824] 03-30 15:22:50:151: IsPublicPhonebook=0
[3824] 03-30 15:22:50:447: RasDialW
[3824] 03-30 15:22:50:447: IsRasmanServiceRunning=1
[3824] 03-30 15:22:50:447: _RasDial(start)
[3824] 03-30 15:22:50:447: GetPbkAndEntryName
[3824] 03-30 15:22:50:447: ReadPhonebookFileEx: called for pbk C:\Users\atm\AppData\Roaming\Microsoft\Network\Connections\Pbk\rasphone.pbk, flags 8
[3824] 03-30 15:22:50:447: IsPublicPhonebook=0
[3824] 03-30 15:22:50:447: path=C:\Users\atm\AppData\Roaming\Microsoft\Network\Connections\Pbk\rasphone.pbk
[3824] 03-30 15:22:50:447: full path=C:\Users\atm\AppData\Roaming\Microsoft\Network\Connections\Pbk\rasphone.pbk
[3824] 03-30 15:22:50:447: IsVirtualizationNeeded: return value = 0
[3824] 03-30 15:22:50:447: ENTRY: Reading “Dial-up Connection”
[3824] 03-30 15:22:50:447: LoadPortsList2
[3824] 03-30 15:22:50:447: GetRasPorts
[3824] 03-30 15:22:50:447: RasPortEnum…
[3824] 03-30 15:22:50:447: RasPortEnum=603,c=10
[3824] 03-30 15:22:50:447: RasPortEnum=0,c=10
[3824] 03-30 15:22:50:447: RasGetDevConfig
[3824] 03-30 15:22:50:447: RasGetDevConfig=603
[3824] 03-30 15:22:50:447: RasGetDevConfig=0
[3824] 03-30 15:22:50:447: SanitizeUnimodemBlob: mdm prot=0
[3824] 03-30 15:22:50:447: Port=COM10,fHw=0,fEc=0,bps=115200,fSp=1,prot=0
[3824] 03-30 15:22:50:447: StringCchCopy failed due to error 0x8007007a
[3824] 03-30 15:22:50:463: LoadPortsList=0
[3824] 03-30 15:22:50:463: successfully finished LoadPortsList2 in ReadEntryList()
[3824] 03-30 15:22:50:463: Reading media group “serial”
[3824] 03-30 15:22:50:463: New link format
[3824] 03-30 15:22:50:463: Port=COM10
[3824] 03-30 15:22:50:463: Port configured
[3824] 03-30 15:22:50:463: SetDefaultModemSettings(bps=115200)=1
[3824] 03-30 15:22:50:463: Reading device group “modem”
[3824] 03-30 15:22:50:463: Device List after deleting dupe
[3824] 03-30 15:22:50:463: StringCchCopy failed due to error 0x8007007a
[3824] 03-30 15:22:50:463: ReadRasFile: ReadEntryList returned 0
[3824] 03-30 15:22:50:463: RASSQM: In ReadPhonebookFile Number of myuse profiles set 1
[3824] 03-30 15:22:50:463: ReadPhonebookFile returns 0
[3824] 03-30 15:22:50:463: GetPbkAndEntryName. rc=0x0
[3824] 03-30 15:22:50:463: looking up subentry 1
[3824] 03-30 15:22:50:463: IsPublicPhonebook=0
[3824] 03-30 15:22:50:463: RasCreateConnection…
[3824] 03-30 15:22:50:463: RasCreateConnection(0) hrasconn=196608, ConnectionAlreadyPresent=0
[3824] 03-30 15:22:50:463: dwIdleDisconnectSeconds=1200
[3824] 03-30 15:22:50:463: SaveProjectionResults…
[3824] 03-30 15:22:50:463: SaveProjectionResults: saving results (dwSubEntry=0)
[3824] 03-30 15:22:50:463: SaveProjectionResults(0)
[3824] 03-30 15:22:50:463: GetInstalledProtocolsEx=0xc.
[3824] 03-30 15:22:50:463: StartAsyncMachine
[3824] 03-30 15:22:50:463: InsertAsyncWorkItem: Calling RasEventLogInitialize
[3824] 03-30 15:22:50:463: InitializeContextQueue: Invalid input parameter
[3824] 03-30 15:22:50:463: starting subentry 1
[3824] 03-30 15:22:50:463: SignalDone: pOverlapped=0xa175620
[3824] 03-30 15:22:50:463: AppendNewContextToQueue:
[3824] 03-30 15:22:50:463: AppendNewContextToQueue:Set Event:
[3824] 03-30 15:22:50:463: RasDialW done(0)
[3856] 03-30 15:22:50:463: WaitForDialMachineEvent
[3856] 03-30 15:22:50:463: WaitForDialMachineEvent: event from dial machine
[3856] 03-30 15:22:50:463: GetOneContextFromQueue
[3856] 03-30 15:22:50:463: GetOneContextFromQueue: The context is:0x000000000A175620,type=2
[3856] 03-30 15:22:50:463: GetOneContextFromQueue: Number of Messages left in the queue is:0
[3856] 03-30 15:22:50:463: ValidateDmContext:
[3856] 03-30 15:22:50:463: ValidateDmContext: hrasconn block verification passed
[3856] 03-30 15:22:50:463: WaitForDialMachineEvent: pOverlapped=0xa175620, type=2
[3856] 03-30 15:22:50:463: WaitForDialMachineEvent: Unblock i=1, h=0xa175580
[3856] 03-30 15:22:50:463: NotifyCaller(nt=0x2,su=1,s=0,e=0,xe=0)…
[3856] 03-30 15:22:50:463: NotifyCaller done (dwNotifyResult=1)
[3856] 03-30 15:22:50:463: GetLogonUser=atm
[3856] 03-30 15:22:50:463: GetLogonDomain=atm-PC
[3856] 03-30 15:22:50:463: RASCS_OpenPort
[3856] 03-30 15:22:50:463: DwOpenPort
[3856] 03-30 15:22:50:463: DwOpenPort: RasPortOpenEx(Quectel USB Modem,0)…
[3856] 03-30 15:22:50:494: DwOpenPort: RasPortOpenEx done(0). Flags=0x2
[3856] 03-30 15:22:50:494: DwOpenPort: PortOpened = COM10
[3856] 03-30 15:22:50:494: DwOpenPort done. 0 (dwSavedError 0)
[3856] 03-30 15:22:50:494: RasSetPortUserData(dialparamsuid) for 9
[3856] 03-30 15:22:50:494: RasSetPortUserData returned 0
[3856] 03-30 15:22:50:494: RasDialMachine:EnableAsyncMachien for RASCS_OpenPort for port:0x9
[3856] 03-30 15:22:50:494: EnableAsyncMachine: hport=9, pasyncmachine=0xa175580, OvDrop=0xa1755e8, OvStateChange=0xa175620, OvProtocolEngine=0xa175658, OvLast=0xa175690
[3856] 03-30 15:22:50:494: EnableAsyncMachine:Set DialEvent to Something
[3856] 03-30 15:22:50:494: RasPortSetInfo(ConnectBPS=115200)…
[3856] 03-30 15:22:50:494: RasPortSetInfo done(0)
[3856] 03-30 15:22:50:494: RasSetConnectionParams…
[3856] 03-30 15:22:50:494: RasSetConnectionParams(0)
[3856] 03-30 15:22:50:494: RasAddConnectionPort(Dial-up Connection,1)…
[3856] 03-30 15:22:50:494: RasAddConnectionPort(0)
[3856] 03-30 15:22:50:494: RasDialMachine errors=0,0
[3856] 03-30 15:22:50:494: RasDialMachine: SignalDone: prasconncb=0xa175570
[3856] 03-30 15:22:50:494: SignalDone: pOverlapped=0xa175620
[3856] 03-30 15:22:50:494: AppendNewContextToQueue:
[3856] 03-30 15:22:50:494: AppendNewContextToQueue:Set Event:
[3856] 03-30 15:22:50:494: WaitForDialMachineEvent
[3856] 03-30 15:22:50:494: WaitForDialMachineEvent: event from dial machine
[3856] 03-30 15:22:50:494: GetOneContextFromQueue
[3856] 03-30 15:22:50:494: GetOneContextFromQueue: The context is:0x000000000A175620,type=2
[3856] 03-30 15:22:50:494: GetOneContextFromQueue: Number of Messages left in the queue is:0
[3856] 03-30 15:22:50:494: ValidateDmContext:
[3856] 03-30 15:22:50:494: ValidateDmContext: hrasconn block verification passed
[3856] 03-30 15:22:50:494: WaitForDialMachineEvent: pOverlapped=0xa175620, type=2
[3856] 03-30 15:22:50:494: WaitForDialMachineEvent: Unblock i=1, h=0xa175580
[3856] 03-30 15:22:50:494: setting rasman state to 1
[3856] 03-30 15:22:50:494: NotifyCaller(nt=0x2,su=1,s=1,e=0,xe=0)…
[3824] 03-30 15:22:50:494: RasGetSubEntryHandleW
[3824] 03-30 15:22:50:494: IsRasmanServiceRunning=1
[3856] 03-30 15:22:50:494: NotifyCaller done (dwNotifyResult=1)
[3856] 03-30 15:22:50:494: RASCS_PortOpened
[3856] 03-30 15:22:50:494: GetUserPreferences(m=0)
[3856] 03-30 15:22:50:494: ReadUserPreferences
[3856] 03-30 15:22:50:494: ReadUserPreferences=0
[3856] 03-30 15:22:50:494: GetUserPreferences=0
[3856] 03-30 15:22:50:494: PhoneNumberFromParts
[3856] 03-30 15:22:50:494: lineGetTranslateCapsW
[3856] 03-30 15:22:50:494: lineGetTranslateCapsW=$8000000E
[3856] 03-30 15:22:50:494: GetCurrentLocation=0
[3856] 03-30 15:22:50:494: PhoneNumberFromPrefixSuffixEx
[3856] 03-30 15:22:50:510: lineGetTranslateCapsW=$8000000E
[3856] 03-30 15:22:50:510: GetCurrentLocation=0
[3856] 03-30 15:22:50:510: PhoneNumberFromPrefixSuffixEx
[3856] 03-30 15:22:50:510: ConstructPhoneNumber: PhoneNumber: *99#
[3856] 03-30 15:22:50:510: ConstructPhoneNumber: DisplayPhoneNumber: *99#
[3856] 03-30 15:22:50:510: FindNextDevice: (MODEM, Quectel USB Modem)
[3856] 03-30 15:22:50:510: RasDialMachine errors=0,0
[3856] 03-30 15:22:50:510: RasDialMachine: SignalDone: prasconncb=0xa175570
[3856] 03-30 15:22:50:510: SignalDone: pOverlapped=0xa175620
[3856] 03-30 15:22:50:510: AppendNewContextToQueue:
[3856] 03-30 15:22:50:510: AppendNewContextToQueue:Set Event:
[3856] 03-30 15:22:50:510: WaitForDialMachineEvent
[3856] 03-30 15:22:50:510: WaitForDialMachineEvent: event from dial machine
[3856] 03-30 15:22:50:510: GetOneContextFromQueue
[3856] 03-30 15:22:50:510: GetOneContextFromQueue: The context is:0x000000000A175620,type=2
[3856] 03-30 15:22:50:510: GetOneContextFromQueue: Number of Messages left in the queue is:0
[3856] 03-30 15:22:50:510: ValidateDmContext:
[3856] 03-30 15:22:50:510: ValidateDmContext: hrasconn block verification passed
[3856] 03-30 15:22:50:510: WaitForDialMachineEvent: pOverlapped=0xa175620, type=2
[3856] 03-30 15:22:50:510: WaitForDialMachineEvent: Unblock i=1, h=0xa175580
[3856] 03-30 15:22:50:510: setting rasman state to 2
[3856] 03-30 15:22:50:510: NotifyCaller(nt=0x2,su=1,s=2,e=0,xe=0)…
[3824] 03-30 15:22:50:510: RasGetConnectStatusW
[3824] 03-30 15:22:50:510: IsRasmanServiceRunning=1
[3824] 03-30 15:22:50:510: SubEntryFromConnection: hrasconn=0x30000, dwSubEntry=1
[3824] 03-30 15:22:50:510: RasGetConnectStatus: read device (MODEM,Quectel USB Modem) from port user data
[3824] 03-30 15:22:50:510: RasGetConnectStatus: read phonenumber *99# from port user data
[3856] 03-30 15:22:50:510: NotifyCaller done (dwNotifyResult=1)
[3856] 03-30 15:22:50:510: GetLogonUser=atm
[3856] 03-30 15:22:50:510: GetLogonDomain=atm-PC
[3856] 03-30 15:22:50:510: RASCS_ConnectDevice
[3856] 03-30 15:22:50:510: RasDeviceSetInfo(Speaker=1)…
[3856] 03-30 15:22:50:510: RasDeviceSetInfo done(0)
[3856] 03-30 15:22:50:510: RasDeviceSetInfo(HwFlowControl=0)…
[3856] 03-30 15:22:50:510: RasDeviceSetInfo(Protocol=0)…
[3856] 03-30 15:22:50:510: RasDeviceSetInfo(Compression=0)…
[3856] 03-30 15:22:50:510: RasGetDevConfig
[3856] 03-30 15:22:50:510: RasGetDevConfig=603
[3856] 03-30 15:22:50:510: RasGetDevConfig=0
[3856] 03-30 15:22:50:510: SanitizeUnimodemBlob: mdm prot=0
[3856] 03-30 15:22:50:510: RasSetDevConfig
[3856] 03-30 15:22:50:510: RasSetDevConfig=0
[3856] 03-30 15:22:50:510: User/pw set for substitution ()
[3856] 03-30 15:22:50:510: RasDeviceSetInfo(UserName=)…
[3856] 03-30 15:22:50:510: SetDeviceParams(modem, Quectel USB Modem, 0)
[3856] 03-30 15:22:50:510: GetRasDeviceString(Quectel USB Modem,CALLBACKTIME)
[3856] 03-30 15:22:50:510: RasDeviceGetInfo…
[3856] 03-30 15:22:50:510: RasDeviceGetInfo=603,s=188
[3856] 03-30 15:22:50:510: RasDeviceGetInfo=0,s=188
[3856] 03-30 15:22:50:510: String=""
[3856] 03-30 15:22:50:510: RasDeviceConnect(modem,Quectel USB Modem)…
[3856] 03-30 15:22:50:525: RasDeviceConnect done(600)
[3856] 03-30 15:22:50:525: RasDialMachine errors=600,0
[3856] 03-30 15:22:50:525: WaitForDialMachineEvent
[3856] 03-30 15:23:10:743: WaitForDialMachineEvent: event from rasman
[3856] 03-30 15:23:10:743: WaitForDialMachineEvent: a context received
[3856] 03-30 15:23:10:743: ValidateDmContext:
[3856] 03-30 15:23:10:743: ValidateDmContext: hrasconn block verification passed
[3856] 03-30 15:23:10:743: WaitForDialMachineEvent: pOverlapped=0xa175620, type=2
[3856] 03-30 15:23:10:743: AppendNewContextToQueue:
[3856] 03-30 15:23:10:743: AppendNewContextToQueue:Set Event:
[3856] 03-30 15:23:10:743: WaitForDialMachineEvent: event from dial machine
[3856] 03-30 15:23:10:743: GetOneContextFromQueue
[3856] 03-30 15:23:10:743: GetOneContextFromQueue: The context is:0x000000000A175620,type=2
[3856] 03-30 15:23:10:743: GetOneContextFromQueue: Number of Messages left in the queue is:0
[3856] 03-30 15:23:10:743: WaitForDialMachineEvent: Unblock i=1, h=0xa175580
[3856] 03-30 15:23:10:743: RasGetInfo…
[3856] 03-30 15:23:10:743: RasGetInfo done(0)
[3856] 03-30 15:23:10:743: Async failure=777
[3856] 03-30 15:23:10:743: RDM: Marking port 9 for closure in RASCS = 2
[3856] 03-30 15:23:10:743: setting rasman state to 2
[3856] 03-30 15:23:10:743: GetLogonUser=atm
[3856] 03-30 15:23:10:743: GetLogonDomain=atm-PC
[3856] 03-30 15:23:10:743: NotifyCaller(nt=0x2,su=1,s=2,e=777,xe=0)…
[3824] 03-30 15:23:10:743: RasGetConnectStatusW
[3824] 03-30 15:23:10:743: IsRasmanServiceRunning=1
[3824] 03-30 15:23:10:743: SubEntryFromConnection: hrasconn=0x30000, dwSubEntry=1
[3824] 03-30 15:23:10:743: RasGetConnectStatus: read device (MODEM,Quectel USB Modem) from port user data
[3824] 03-30 15:23:10:743: RasGetConnectStatus: read phonenumber *99# from port user data
[3824] 03-30 15:23:10:743: RasHangUpW
[3856] 03-30 15:23:10:743: NotifyCaller done (dwNotifyResult=0)
[3856] 03-30 15:23:10:743: Discontinuing callbacks for hrasconn 0x30000
[3856] 03-30 15:23:10:743: Cleared notifier for hrasconn 0x30000 subentry 1
[3856] 03-30 15:23:10:743: RDM: RasGetInfo, port=9 returned 0
[3856] 03-30 15:23:10:743: RDM: DisconnectPort 9…
[3856] 03-30 15:23:10:759: RDM: DisconnectPort comleted. 0
[3856] 03-30 15:23:10:759: RDM: PortClose 9 …
[3856] 03-30 15:23:10:774: RDM: PortClose 9 Completed. 0
[3856] 03-30 15:23:10:774: Quitting s=2,e=777
[3856] 03-30 15:23:10:774: Asyncmachine: Cleaning up
[3824] 03-30 15:23:10:774: (HU) RasFindPrerequisiteEntry, 0x30000
[3824] 03-30 15:23:10:774: (HU) RasFindPrerequisiteEntry, 0x30000. hConnPrereq=0x0, rc=0
[3824] 03-30 15:23:10:774: (HUC) RasRefConnection(FALSE), 0x30000 …
[3824] 03-30 15:23:10:774: (HUC) RasRefConnection(FALSE), 0x30000. ref=0, rc=0
[3824] 03-30 15:23:10:774: (HU) RasDestroyConnection(196608)…
[3824] 03-30 15:23:10:774: (HU) RasDestroyConnection done(668)
[3856] 03-30 15:23:10:774: RasDialCleanup…
[3856] 03-30 15:23:10:774: CleanUpRasconncbNode
[3856] 03-30 15:23:10:774: StopAsyncMachine
[3856] 03-30 15:23:10:774: EnableAsyncMachine:Clear DialEvent for port:9 to NULL
[3856] 03-30 15:23:10:774: (CU) RasProtocolStop…
[3856] 03-30 15:23:10:774: (CU) RasProtocolStop done
[3856] 03-30 15:23:10:774: DeleteRasconncbNodeCommon: prasconncb=0xa175570
[3856] 03-30 15:23:10:774: CloseAsyncMachine
[3856] 03-30 15:23:10:774: RemoveAsyncWorkItem: Calling RasEventLogUninitialize
[3856] 03-30 15:23:10:774: CleanUpRasconncbNode done
[3856] 03-30 15:23:10:774: RasDialCleanUp done.
[3856] 03-30 15:23:10:774: WaitForDialMachineEvent
[3856] 03-30 15:23:10:774: WaitForDialMachineEvent: event from rasman
[3856] 03-30 15:23:10:774: WaitForDialMachineEvent: a context received
[3856] 03-30 15:23:10:774: ValidateDmContext:
[3856] 03-30 15:23:10:774: ValidateDmContext: hrasconn block verification passed
[3856] 03-30 15:23:10:774: WaitForDialMachineEvent: pOverlapped=0xa1755e8, type=1
[3856] 03-30 15:23:10:774: AppendNewContextToQueue:
[3856] 03-30 15:23:10:774: AppendNewContextToQueue:Set Event:
[3856] 03-30 15:23:10:774: WaitForDialMachineEvent: event from dial machine
[3856] 03-30 15:23:10:774: GetOneContextFromQueue
[3856] 03-30 15:23:10:774: GetOneContextFromQueue: The context is:0x000000000A1755E8,type=1
[3856] 03-30 15:23:10:774: GetOneContextFromQueue: Number of Messages left in the queue is:0
[3856] 03-30 15:23:10:774: Skipping completed asyncmachine pointer: 0xa175580
[3856] 03-30 15:23:10:774: WaitForDialMachineEvent: pOverlapped=0xa175690, type=4
[3856] 03-30 15:23:10:774: WaitForDialMachineEvent:last message from Rasman
[3856] 03-30 15:23:10:774: GetOneContextFromQueue: The context is:0x000000000A175690,type=4
[3856] 03-30 15:23:10:774: WaitForEvent:Received OVEVT_DIAL_LAST
[3856] 03-30 15:23:10:774: asyncmachine=0xa175580: last event for hport=9, freefunc()
[3856] 03-30 15:23:10:774: RasDialFinalCleanup: deallocating prasconncb=0xa175570
[3856] 03-30 15:23:10:774: FinalCleanUpRasconncbNode: deallocating prasconncb=0xa175570
[3856] 03-30 15:23:10:774: FinalCleanUpRasconncbNode: 0 nodes remaining
[3856] 03-30 15:23:10:774: ShutdownAsyncMachine: pOverlapped=0xf48fc480
[3856] 03-30 15:23:10:774: ShutdownAsyncMachine: PostcontextToDialMachine() succeeds!
[3856] 03-30 15:23:10:774: GetOneContextFromQueue: The context is:0x000007FEF48FC480,type=5
[3856] 03-30 15:23:10:774: WaitForDialMachineEvent: pOverlapped=0xf48fc480, type=5
[3856] 03-30 15:23:10:774: WaitForDialMachineEvent: OVTEVT_DIAL_SHUTDOWN event received
[3856] 03-30 15:23:10:774: WaitForDialMachineEvent: Unblock i=3, h=0xa175580
[3856] 03-30 15:23:10:774: AsyncMachineWorker:WaitForDialMachineEvent failure:0x3eb
[3856] 03-30 15:23:10:774: AsyncMachineWorker terminating
[3856] 03-30 15:23:10:774: CleanUpContextQueue:
[3824] 03-30 15:23:12:755: RasGetAutodialParamW
when I checked the module with QNavigator_V1.4 eveything is ok even it shows the module is registered in the network.
Then I found out when I shutdown Windows 7, dial up connection will works ok.
if you have another dirver which is operational for EC20 PCIe modem our other thing which can solve this problem please help me know.
With all respect,
