I’m running an EC20CEFDG module with firmware EC20CEFDGR08A02M4G on LG U+ (45006). The modem attaches to LTE normally, SMS works, data works, IMS is enabled, and the ims APN is set up.
The issue is that voice calls behave differently depending on the destination:
Calls to LG U+ mobile numbers alert but then drop with NO CARRIER.
Calls to KT mobiles connect fine.
Calls to LG U+ IP phones connect fine.
Service code 114 also works.
I tried the usual settings (dedicated IMS APN, UA string set to TTA-VoLTE/2.0 … LGU, AMR codecs enabled, just in case), but it doesn’t change the behavior.
I know that with firmware EC20CEFDGR06A11M4G this use case already works on LG U+, but with R08A02M4G I’m seeing this problem.
Is there any known difference in VoLTE handling between these firmware versions, or a patch that needs to be applied for R08A02M4G?
Thanks.
