I have an application that requires APN to be configured on the fly. Is it possible to Automatically detect the APN of the inserted SIM with any AT command?
Also I need to detect if the SIM module is inserted or not, but my SIM module does not have a detect switch. Is it possible to detect SIM insertion and removal with some other command?
I am using a custom board consisting of an EC20 module connected to a microcontroller to store the AT commands.
Dear Sir,
The module cannot support to detect APN automatic, but the network have such function, you need to check with your local operator. Thanks!
The module have the SIM_Presence pin which can used to detect whether you have insert SIM card or not. Please check the following design circuit, if you want to use such function, you need to make sure the SIM card circuit of your board design as the following picture, then you can use AT+QSIMEDT to set it. Thanks!
I am in a similar situation. I have two series of modems both are EC200U-CN but has different serial no printed on them like Q1-A9401 and Q1-C0970. I am setting the apn using AT+CGDCONT= 1, “IP”, “apn1” command for both the modems. Some weeks ago the network provide changed the APN. Q1-C0970 modem is working even if I set the older apn using the CGDCONT command. However, for the Q1-A9401 modem I had to change the APN to new APN with CGDCONT command to make it work?
It seems that the Q1-C0970 modem is able to correct the apn using network, but Q1-A9401 is not able to. Why is this difference? This issue is causing many of our devices in field to stop communicating.
