e-SIM on BG95-M3
Dear Quectel team,
I would like to clarify the current status of eSIM (eUICC) support on the BG95-M3 module. I have found several threads in this forum regarding this topic, but none of them provides a definitive and up-to-date answer.
Could you please confirm the following:
  1. Does the BG95-M3 officially support GSMA-compliant eSIM (SGP.02)?
  2. If so, is special firmware required to enable the related AT commands (e.g. AT+QESIM, AT+QECC, etc.)?
  3. How can I obtain the correct firmware version that enables full eSIM/RSP functionality?
Thank you in advance for your assistance.
Best regards,
Iker
The eSIM function only supported by specific firmware.
And this feature needs to be upgraded to a customized version.
There is currently no released version support.
Thanks mikey. Please, can you explain how can I get the customized version?
I assume from the lack of response that, despite the BG95 datasheet clearly stating eSIM support, this feature is either not available or not officially supported.
If this is not the case, I would appreciate any clarification from the manufacturer or community.
