Dual USIM Support on UMTS&LTE EVB R2.0
I’m using a UMTS&LTE EVB R2.0 with a EG91-NA and trying validate the dual sim function.
The primary sim card slot (J702) is working perfectly. This EVAL board has a secondary sim card slot installed (J703), but I cannot get the EG91 to recognize it. Is it connected to the EG91 in a way that is compliant to the dual sim function? The EVB documentation says it is not mounted and reserved for future use, but it is on my board.
With both sim cards inserted, I see:
+QSIMDET: 1,1
+QDSIM: (0.,1)
If it supported in the EVB board, then can you please provide an example of how to configure the use of the J703 card holder?
Thanks kindly,
Ch
Hi @IOTGUY
Can you give your e-mail,and i will send the Quectel_EG91_Series_Hardware_Design_V2.2 to you.You may refer to the instruction manual.
Hello @IOTGUY , can you give an update what the outcome is? Is the J703 useable as second SIM with EG91 (it is actually EG912 in my case)?
@lyman-Q , can you provide the Quectel_EG91_Series_Hardware_Design_V2.2 ?
BR
Hi @IOTGUY @tombeeftimonant
Any update on the above query? since i am also facing the same issue
Best Regards
Hi @Barathkumar_S ,
yes, I figured that the named EVB’s 2nd SIM slot is not useable. If you want to test the dual-sim feature of the eg912, you may want to order the “EG912N-EN-TE-A with LTE OPEN EVB” board.
BR
