I am using a BG96 and trying to setup DTLS with Pre-Shared Keys. Is there a format for the file that is needed to be used for AT+QSSLCFG=“clientkey” command? Thank you!
The default format is pSK , you can use other format also ,
it is same as ssl connection .
I attached one doc for your referenceQuectel_BG96_SSL_Application_Note_V1.1.pdf (487.3 KB)
This is a very help application note, thank you!
