Please show the device mananger.
hello,
I have a EC200A-EU, using in a dongle usb
I install the driver, but thats fails:
mobile ECM network adapter…
under win10
PLEASE HELP ME
EC200A-EU
hello,
I install this driver, all solved
but not for :
Mobile ECM network Adapter.
Can you help me please?
BR JJ
Please send-me latest firmware for EC200A-EU!
Could you please send me the latest ec200a-eu firmware?
Current:
AT+QGMR
EC200AEUHAR01A12M16_01.001.01.001
I need drivers as well please, same problem. “kaxagvimraze@gmail.com”
thanks
hello
i need this firmware to upgrade my module
please help me
please send this firmware to me
thanks.
What is the current firmware version?
Hi
Current firmware is
EC200AEUHAR01A13M16
@Peyman_Shiri
Please try the EC200AEUHAR01A26M16_01.200.01.200.
Hello i have this firmware:
EC200AEUHAR01A19M16_01.200.01.200 but i have a big problem because only registered in GSM with reset, there are a new firmware? is installed on Mikrotik RBwAPR-2nD
Please Help me, thank you Luigi.
Hi,@LuigiUnidata
The lastest firmware have already sent to you via email,pls check.
i need this firmware please EC200AEUHAR01A26M16_01.200.01.200
yossib@ip-com.co.il or to yossixdr@gmail.com thank you very much!
I need it too please, thanks
Loastaal[AT]protonmail[DOT]com
by the way, why it’s available directly in download ? ![]()
Hi,@yossixdr
I have sent to you via email,pls check.
Hi,@Thomas_Chereau
Could you tell me your current firmware version? You can use the “ATI” command to check it.
Regarding why it can’t be downloaded directly, it’s because upgrading with the wrong firmware may lead to module abnormalities. Thank you for your understanding.
I have currently “EC200AEUHAR01A19M16_01.200.01.200” installed
[admin@MikroTik] > /interface/lte/at-chat lte1 input=ATI
output: Quectel
EC200A
Revision: EC200AEUHAR01A19M16
Hi,@Thomas_Chereau
