Hello there,
I’m wondering, does the EC21 module support Long Message Service (LMS/2,000byte)?"
Hello there,
Text-mode or PDU-mode?
The size should make no difference in PDU-mode.
Is it possible to send long messages, such as LMS of up to 2,000 bytes, regardless of whether in TEXT mode or PDU mode?
All SMSs travel over-the-air as PDUs.
With a modem in text-mode, the modem is responsible for all conversions between text and PDUs.
So support for long messages in text-mode depends entirely on the capabilities of modem firmware.
In PDU-mode, the modem is given the long message parts pre-encoded. Likewise, decoding of multi-part SMSs in PDU-mode is the responsibility of software external to the modem.
256 message parts each containing 153 7-bit characters from the GSM default alphabet are theoretically possible in PDU mode.
If a message uses even a single character which is not in the GSM default alphabet, then the entire message (including all parts) must use 16-bit UCS-2 encoding. This reduces the payload size by more than 50%
Not all modems support UCS-2 in text-mode.
I don’t know the text-mode limitations of the EC21, sorry.
