Does EM06K-EA support QMI?
I am trying to find out whether EM06K-EA supports QMI. It is listed in option.c
https://elixir.bootlin.com/linux/latest/source/drivers/usb/serial/option.c#L263
And shows up as a serial interface, however does not appear to create a cdc-wdm device.
There is no explicit mention of it here
https://elixir.bootlin.com/linux/latest/source/drivers/net/usb/qmi_wwan.c#L1086
The EM06 supported QMI, and QConnectManager says it supports EM060K-GL - is that a different modem entirely? But I don’t see any mention of EM06K-EA
Please show the output of cat /sys/kernel/debug/usb/devices
T:  Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480  MxCh= 2
B:  Alloc=  0/800 us ( 0%), #Int=  0, #Iso=  0
D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=01 MxPS=64 #Cfgs=  1
P:  Vendor=1d6b ProdID=0002 Rev= 5.04
S:  Manufacturer=Linux 5.4.188 xhci-hcd
S:  Product=xHCI Host Controller
S:  SerialNumber=1e1c0000.xhci
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=  0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
E:  Ad=81(I) Atr=03(Int.) MxPS=   4 Ivl=256ms
T:  Bus=01 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#=  6 Spd=480  MxCh= 0
D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=2c7c ProdID=030b Rev= 5.04
S:  Manufacturer=Quectel
S:  Product=EM060K-EA
S:  SerialNumber=7a64face
C:* #Ifs= 7 Cfg#= 1 Atr=a0 MxPwr=500mA
A:  FirstIf#= 8 IfCount= 2 Cls=02(comm.) Sub=0e Prot=00
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=30 Driver=option
E:  Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=40 Driver=option
E:  Ad=83(I) Atr=03(Int.) MxPS=  10 Ivl=32ms
E:  Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=40 Driver=option
E:  Ad=85(I) Atr=03(Int.) MxPS=  10 Ivl=32ms
E:  Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=40 Driver=option
E:  Ad=87(I) Atr=03(Int.) MxPS=  10 Ivl=32ms
E:  Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 8 Alt= 0 #EPs= 1 Cls=02(comm.) Sub=0e Prot=00 Driver=(none)
E:  Ad=88(I) Atr=03(Int.) MxPS=  64 Ivl=32ms
I:* If#= 9 Alt= 0 #EPs= 0 Cls=0a(data ) Sub=00 Prot=02 Driver=(none)
I:  If#= 9 Alt= 1 #EPs= 2 Cls=0a(data ) Sub=00 Prot=02 Driver=(none)
E:  Ad=8e(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=0f(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#=12 Alt= 0 #EPs= 1 Cls=ff(vend.) Sub=ff Prot=70 Driver=(none)
E:  Ad=89(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
T:  Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=5000 MxCh= 1
D:  Ver= 3.00 Cls=09(hub  ) Sub=00 Prot=03 MxPS= 9 #Cfgs=  1
P:  Vendor=1d6b ProdID=0003 Rev= 5.04
If it is supported, then perhaps the issue is simply that I need to add EM06K-EA’s product id to here
(which is 0x030b)
You have EM060K-EA (please correct the topic title) in MBIM mode with cdc_mbim driver missing.
You can run AT+QCFG=? and see what are the supported values for AT+QCFG="usbnet", that should give you an idea about what modes are available.
I have also tried it with QMI mode, (QCFG usbnet “0”), it just happened to be in MBIM mode when I gave you those logs as I was trying both modes - the result was the same
Yes looks like adding
{QMI_MATCH_FF_FF_FF(0x2c7c, 0x030b)},	/* Quectel EM060K */
To qmi_wwan.c and making sure the required device was in option.c got it to work
