Does EG915U support AT^DSCI command
I am workin with EG915U-EC firmware version EG915UECABR03A04M08_01.200.01.200
I see that GSM module respond to AT^DSCI although it is missing in AT commands document.
The question is: iI AT^DSCI is supported by this module, so I can use it, or there is some kind of issue with it and I should not relay on it?
Regards,
Dimitar
Hi @dimitar_dev ,
This command can be used normally on EG915U.
