I am doing kernel changes on linux-6.1. Modem EC200A is already defined in this version, but your Linux_USB_Driver_User_Guide guide states that I should make this change in option.c driver:
if (dir == USB_DIR_OUT) {
struct usb_device_descriptor *desc = &serial->dev->descriptor;
if (desc->idVendor == cpu_to_le16(0x2C7C))
urb->transfer_flags |= URB_ZERO_PACKET;
This was relevant by my opinion before introducing ZLP flag. But line which defines modem does not use ZLP flag.
{ USB_DEVICE_AND_INTERFACE_INFO(QUECTEL_VENDOR_ID, QUECTEL_PRODUCT_EC200U, 0xff, 0, 0) }
Is this correct?
Because in usb_wwan.c I will never pass this condition
if (intfdata->use_zlp && dir == USB_DIR_OUT)
Are you sending zero packets at the end of bulk transfer or not (because some modems do that some does not), should I integrate change mention in Linux USB Driver?
Greetings
