I’m not sure regarding the correct way on how to decode the and information for GSM serving and neighbour cells.
According to the documentation on band:
Integer type. The current band. 0 DCS_1800 1 PCS_1900 “-” other bands.
One example response for a GSM serving cell is:
+QENG: “servingcell”,“NOCONN”,“GSM”,262,01,4818,B02C,3,73,2,-56,0,4,0,51,51,1,-,-,-,-,-,-,-,-,-,“-”
According to this, the band is “2” which is not documented.
Furthermore, the value is shown as “-56”, while the documentation says:
Integer type. RX level value for base station selection in dB (see 3GPP 25.304). Range: 0-63. Subtracting 111 from the RX level value, a dBm value will be got.
I guess the -56 is the dBm value already.
I’m using documentation Quectel_EC2xEG9xEG2x-GEM05_Series_AT_Commands_Manual_V2.0.pdf.
The module used is an EC200S.
Any hint is welcome.
Best Regards,
Stefan
