Documentation for AT+QNWCFG
I am looking for official documentation for the following AT+QNWCFG options:
  • AT+QNWCFG=“nr5g_pusch_data”
  • AT+QNWCFG: “nr5g_l1_info”
  • AT+QNWCFG=“nr5g_ulTBsize”
  • AT+QNWCFG=“nr5g_ulMCS”
  • AT+QNWCFG=“nr5g_dlMCS”
  • AT+QNWCFG=“nr5g_tx_pwr”
  • AT+QNWCFG=“nr5g_time_advance”
  • AT+QNWCFG=“nr5g_meas_info”
  • AT+QNWCFG=“nr5g_csi_ext”
I have the following chips: RG502Q-EA, RG520F-EU, RG650E-EU
Thank you!
Best,
Birkan
I have sent them to your email,pls check
Hello Herbert,
Thank you for your kind response. I received your email.
Unfortunately, the commands that I am searching for are not documented in the PDFs that you have sent me.
I can see the commands on the 5G modules. Is this information not public?
Best,
Birkan
Are you referring to these configuration items?
Yes, Herbert. I am looking into those configuration items.
If you have documentation for any of them, this would be highly appreciated.
I would like to get all of them if possible.
Thank you!
These configuration items might not be publicly available. The latest updated documentation does not contain these configuration items.
Thank you, Herbert! I understand.
On the Quectel website, I only found the hardware design documentations for RG502Q-EA and RG520F-EU:
  • Quectel_RG50xQ_Series_Hardware_Design_V1.4
  • Quectel_RG520FRG520N_Series_Hardware_Design_V1.6.pdf
Do you have official documentation for RG650E Hardware Design?
Dear @birkandenizer
Do you use Quecopen solution?
Dear @silvia,
We are using off-the-shelf MikroTik routers such as the Chateau 5G line, which uses RG502Q-EA, RG520F-EU, and RG650E-EU chips. In many scenarios, we are connecting them to external antennas for maritime use cases, so we need to get an accurate port layout for maximum uplink configuration across 5G NR bands for remotely controlled devices.
In addition to hardware design documents, we also need up-to-date documentation for the AT commands for data collection. Herbert kindly forwarded me the latest AT command documentation for RG520F-EU and RG650E-EU. However, it is very limited and does not include options such as AT+QNWCFG=“nr5g_pusch_data” that I have mentioned in my first message.
Therefore, I am looking for both the hardware design document for the RG650E-EU and the latest AT command manuals for AT+QNWCFG=“nr5g_pusch_data”, AT+QNWCFG: “nr5g_l1_info”, AT+QNWCFG=“nr5g_ulTBsize”, etc.
Best,
Birkan
Dear @birkandenizer
RG650E only support Quecopen solution, please note this.
For other AT commands, we don’t have document for this.
Hello @silvia
Could you please explain a bit about the output of the AT+QNWCFG=“nr5g_csi” command?
However, here is my output, in a 5G-SA network:
+QNWCFG: “nr5g_csi”,0,3,12,7
+QNWCFG: “nr5g_csi”,0,3,12,4
Where can I find the mapping of the MCS in 5G NR to integers?
Also, is there any documentation about AT+QNWCFG
Thanks,
Dear @Jameel_Ali
Which module do you use? Please share, I will check.
Hello @silvia
RM505Q-AE
Revision: RM505QAEAAR11A03M4G
at+qnwcfg=?
+QNWCFG: “lte_cdrx”,(0,1),(0,1)
+QNWCFG: “nr5g_cdrx”,(0,1)
+QNWCFG: “csi_ctrl”,(0,1),(0,1)
+QNWCFG: “lte_csi”
+QNWCFG: “nr5g_csi”
+QNWCFG: “lte_cell_id”
+QNWCFG: “nr5g_cell_id”
+QNWCFG: “lte_csi_ext”,(0,1)
+QNWCFG: “nr5g_csi_ext”,(0,1)
+QNWCFG: “lte_tx_pwr”,(0,1)
+QNWCFG: “nr5g_tx_pwr”,(0,1)
+QNWCFG: “wcdma_cqi”
+QNWCFG: “up/down”,(1-60)
+QNWCFG: “data_path”,(0,1)
+QNWCFG: “dss_enable”,(0,1)
+QNWCFG: “lte_dl_tx_mode”
+QNWCFG: “nr5g_ulMCS”,(0,1)
+QNWCFG: “nr5g_dlMCS”,(0,1)
+QNWCFG: “nr5g_pusch_data”,(0,1)
+QNWCFG: “lapi”,(0,1)
+QNWCFG: “nr5g_meas_info”,(0,1)
+QNWCFG: “lte_time_advance”,(0,1)
+QNWCFG: “nr5g_time_advance”,(0,1)
+QNWCFG: “clr_rplmn”
+QNWCFG: “dis_rplmnact”,(0,1)
+QNWCFG: “lte_ambr”
+QNWCFG: “nr5g_ambr”
+QNWCFG: “dis_4mimo_enable”,(0,1)
+QNWCFG: “nr5g_ulTBsize”,(0,1),(1-100)
+QNWCFG: “encryp_alg_support”
+QNWCFG: “integ_alg_support”
+QNWCFG: “data_roaming”,(0,1)
+QNWCFG: “nr5g_earfcn_lock”,(0-32),earfcn1:scs1:…:earfcnN:scsN
+QNWCFG: “lte_earfcn_lock”,(0,1),earfcn1:earfcn2
+QNWCFG: “event_a3_offset”,(0,1),(0-255)
+QNWCFG: “used_algo”,(0,1)
+QNWCFG: “nr5g_pref_freq_list”,(0-32),earfcn1:scs1:…:earfcnN:scsN
+QNWCFG: “lte_pref_freq_list”,(0-32),earfcn1:…:earfcnN
+QNWCFG: “ehplmn_config”,(0-20),plmn1:plmn2:…:plmnN
+QNWCFG: “nr5g_mimo”,(0,1)
+QNWCFG: “ctrl_plane_dly”,(0,1)
+QNWCFG: “rrc_state”
+QNWCFG: “ssb_beam_id”,(0,1)
+QNWCFG: “ul_data_path”,(0,1)
+QNWCFG: “lte_ulMCS”,(0,1)
+QNWCFG: “lte_mimo_layers”
+QNWCFG: “nr5g_mimo_layer”,(0,1)
+QNWCFG: “lte_band_priority”,
+QNWCFG: “cause7_map_cause14”,(0,1)
Dear @Jameel_Ali
Hello @silvia
Thank you for sharing the document.
Unfortunately, it does not contain most of the QNWCFG commands supported by the modem, such as AT+QNWCFG=“nr5g_csi_ext”, AT+QNWCFG=“nr5g_tx_pwr”, and others.
Could you please share the updated version of the documentation with me?
Dear @Jameel_Ali
Hello @silvia
Thank you so much. Could you please give me the documentation of “ AT+QNWCFG="nr5g_pusch_data”?
BR,
Jameel
Dear @Jameel_Ali
