Basic illustration
This article tells how to used modbus DTU.
Application case of modbus
from usr.sensor import ModbusInit
import usr.uModBusConst as Const
from machine import UART
import utime as time
# LightSensor UART info
uart_port = UART.UART0
bardrate = 9600
databits = 8
parity = 0
stopbit = 1
flowctl = 0
# sensor addrinfo
slave = 0x01
const = Const.READ_HOLDING_REGISTERS
start_addr = 0X03
coil_qyt = 0x02
# light data transfer
def light_data_transfer(ret_str):
str_list = list(map(lambda x: x.decode("utf-8"), ret_str.split(b",")))
data_bits = int(str_list[2])
data_list = str_list[3: 3+data_bits]
one_place = int("0x" + data_list[0] + data_list[1], 16)
tens_place = int("0x" + data_list[2] + data_list[3], 16)
return tens_place * 10 + one_place
if __name__ == '__main__':
modbus = ModbusInit(uart_port, bardrate, databits, parity, stopbit, flowctl)
while True:
modbus.write_coils(slave, const, start_addr, coil_qyt)
ret_str = modbus.read_uart()
print(ret_str)
digit_val = light_data_transfer(ret_str)
print(digit_val)
time.sleep_ms(1000)
Application note of modbus API
modbus_utils.init (uartN, buadrate, databits, parity, stopbit, flowctl)
Initialize UART port
Parameter
Type
Illustration
uartN
int
UART0 - DEBUG PORT UART1 – BT PORT UART2 – MAIN PORT UART3 – USB CDC PORT
buadrate
int
Baud rate, common baud rates are supported. 4800、9600、19200、38400、57600、115200、230400
databits
int
Data bits (5~8), the Unisoc just supports 8 bits
parity
int
Parity validation(0 – NONE,1 – EVEN,2 - ODD)
stopbits
int
Stop bits(1~2)
flowctl
int
HW flow control(0 – FC_NONE, 1 – FC_HW)
modbus_utils.divmod_low_high(addr)
Split the high and low bit of address
Input parameter
Type
Illustration
addr
int
Hex address
Returned value
Type
Illustration
high
int
Hex address of high bits
low
int
Hex address of low bits
modbus_utils.calc_crc(string_byte)
Calculate the value of bytearray parity bit.
Parameter
Type
Illustration
string_byte
bytearray
bytearray
Type of returned value
Type
Illustration
crc_high
int
CRC high bit address
crc_low
int
CRC low bit address
modbus_utils.split_return_bytes(ret_bytes)
Split the bytes read from UART port and convert as bytearray
Parameter
Type
Illustration
ret_bytes
bytes
bytes
Type
Illustration
bytes_split
list
List after splitting bytes, the format is shown as [b’00’, b’1E’, …..]
modbus_utils.read_uart()
Read the uart data and return bytes value
Type
Illustration
bytes_string
bytes
Format : b”01,1E,1F…..”
modbus_utils.write_coils(slave, const, start, coil_qty, crc_flag=True)
Write coils
Parameter
Type
Illustration
slave
int
Device address
const
int
Functional code
start
int
Starting address
coil_qty
int
Read coil quantity
crc_flag
bool
Whether the parity is needed
Type
Illustration
status
bool
Return True
modbus_utils.write_coils_any(*args, crc_flag=True)
Write any coil address
Parameter
Type
Illustration
*args
list
List by any byte
crc_flag
bool
Functional code list of uModBusConst
Name
Address
READ_DISCRETE_INPUTS
0X02
READ_COILS
0X01
WRITE_SINGLE_COIL
0X05
WRITE_MULTIPLE_COILS
0X0F
READ_INPUT_REGISTER
0X04
0X03
WRITE_SINGLE_REGISTER
0X06
WRITE_MULTIPLE_REGISTERS
0X10
READ_WRITE_MULTIPLE_REGISTERS
0X17
MASK_WRITE_REGISTER
0X16
READ_FIFO_QUEUE
0X18
READ_FILE_RECORD
0X14
WRITE_FILE_RECORD
0X15
READ_EXCEPTION_STATUS
0X07
DIAGNOSTICS
0X08
GET_COM_EVENT_COUNTER
0X0B
GET_COM_EVENT_LOG
0X0C
REPORT_SERVER_ID
0X11
READ_DEVICE_IDENTIFICATION
0X2B
I want to implement modbus using QuecPython on the EC200U-CN. But I’m getting an error that the modules usr.sensor and usr.uModBusConst don’t exist
hi, Tanmayee
Please refer to the following script.
modbus_RTU.py (22.1 KB)
Sumeri_Lal:
监控函数, 实际线程以参数传入(Thread monitoring function, the actual thread passed in as an argument)
hi,Sumeri
Thank you for your information. I am confirming it. I will give you feedback as soon as possible
Hi Felix,
There was the problem with Logic Level Convertor at the end of MAX485. I have changed logic level convertor. Now, Its working fine. That was a hardware issue. I am sorry for rising issue.
Thanks so much for your support.
