Application notes of Watchdog development
In this document, it mainly introduces how to use QuecPython_Watchdog on EC600S (applicable to other modules). The watchdog is usually used to prevent getting stuck of the device. It will reboot the module once the device gets stuck by adding Watchdog. In this document, you will learn all parameters and application notes of WDT (the acronym of Watchdog).
About HW
The function of WDT: The reboot will occur under the circumstance that failure to execute by the exception in APP. Since this function is embedded in interior, no peripheral circuit is needed.
Interaction
- Interact with module via QPYcom, here shows the case:
Notes:
- The purpose of executing "from machine import WDT " is to make the WDT vivid in current space.
- Only execute "from machine import WDT " can the function and variate in WDT be used.
Note: If there is no behavior of feeding dog, the system will reset automatically after 2 s.
Download and verify
Download .py file and run it on module, here shows the code
from machine import Timer
count = 0
def feed(t):
global count
count += 1
if count >= 5:
print('Stop feeding')
timer1.stop()
print('Feed')
wdt.feed()
timer1 = Timer(Timer.Timer1)
wdt = WDT(2) # Initiate watchdog, the intervel time. the unit is s.
timer1.start(period=1000, mode=timer1.PERIODIC, callback=feed) # Feed by timer
SW design
For specific Watchdog API, please refer to the link: Watchdog API
- Function prototype WDT (period): return a wdt object to set the feed, start and stop function of WDT.
Create WDT object and initiate immediately
wdt = WDT(period)
| Parameter | Type | Illustration |
| period | int | Set the detection time of SW watchdog, the unit is āsā |
- Function prototype feed(): no return value
Feed
wdt.feed()
- Function prototype stop(): no return value
Stop SW Watchdog function
wdt.stop()
Term explanation
Watchdog: It will reset the whole system compulsorily since the program will be considered as failure to work once the count is added to threshold.
Feed: Reset count value
