[Document sharing]-FOTA_ASR
FOTA_binary_upgrade FW upgrade
In this document, it mainly introduces how to upgrade FW based on EC600S-CNLA module. Furthermore, you will learn about FOTA of EC600S-CNLA after reading this paper.
Operation Procedure
  1. Export upgrade file
Copy the system.img from the new and old zips separately, the rename them as system_old.img and system_new.img individually. Please check the next figure:
  1. Configure file.
[Image_List]
Number_of_Images = 1
1_Image_Enable = 1
1_Image_Image_ID = 0x30
1_Image_Path = system.bin
1_Image_Flash_Entry_Address = 0x00024000
1_Image_ID_Name = 1
  1. Make .bin file
Duplicate the system_old .img and system_new.img into the root directory of FOTA tool, then execute commands as described below: adiff.exe -l fp system_old.img system_new.img FotaFile.bin.
Result after executing
FOTA_ASR_04
The FoteFile.bin file will be generated for the module to download and upgrade.
  1. Locate the upgraded file into http server.
The address used to download in this test is http://120.197.216.227:6000/FotaFile.bin
SW design
import fota
import utime
DEF_URL1 = 'http://120.197.216.227:6000/FotaFile.bin'
def result(args):
    print('download status:', args[0], 'download process:', args[1])
def run():
    fota_obj = fota()  # Build Fota object
    print("Enter upgrade status......")
    res = fota_obj.httpDownload(url1=DEF_URL1, callback=result)
    if res != 0:
        return
    utime.sleep(2)
run()
Download and verify
SW code
Download the .py file and run on module
After downloading, run the script manually.
About 5 minutes later, the upgrade will be complete, then you can check:
Transmit in interaction surface
>>> modem.getDevFwVersion()
'EC600SCNLAR01A01M16_OCPU_PY_BETA0414'
As the above figure implies, the verification is a success.
