[Document sharing]-FileSyste Application Guide
Brief introduction
In this document, it mainly introduces how to operate and deploy QuecPython file system. The file system plays the role of making sure the storage device (Generally, it is the disk; however, SSD based on NAND Flash is also available) in operation system or the method of file in partition as well as the data structure. That is the way to organize file on storage device. In most cases, the software organization which is responsible for managing and storing file information in an operating system is called file management system (It is also abbreviated as file system). After learning about this document, you will take charge of the operation and application note of file system.
About saving file into file system
Download and debug file via QPYcom
Download script
Several ways are achievable to download script.
(1)Drag the file into module via the “Dragging” function in QPYcom;
(2)Download the script to module via the “Downloading script” function of QPYcom ;
Note: For specific script downloading, please refer to .
File operation
For how to operate QuecPython file system, you can take uos module and uiomodule as references.
For various ports, please take following cases as examples:
import uos
uos.getcwd() # Get path
uos.chdir(‘/usr’) # Change path
uos.mkdir(‘QuecPython’) # Make file in current path
uos.listdir()
[‘apn_cfg.json’, ‘a.py’, ‘b.py’, ‘V05.bin’, ‘system_config.json’, ‘checksum.json’, ‘b.txt’, ‘QuecPython’]
uos.chdir(‘QuecPython’)# Change path
uos.getcwd()
‘/usr/QuecPython’
import uio
fd = uio.open(‘test.py’, mode=‘w’) # Make new file in current file and open it by written
fd.write(‘quectel’) # Write
7
fd.close() # Close file
fd = uio.open(‘test.py’, mode=‘r’) # As for the file in current file, open it by read
fd.read() # Read
‘quectel’
fd.close()
The way to generate bin in mass production file
As for the FW merge, actually, the customer_fs.bin has been generated. Here shows the principle:
  1. Find mklfs in the directory of QPYcom_v1.7\exes\aboot after unzipping QPYcom. After that, open following contents via commands in mklfs tool directory.
  1. Make a folder named mount, then place the file to be merged in this folder.
  1. Execute commands
(1)The commands to generate .bin file are shown as above, while for specific illustration, please check the figure:
(2)As above figure shows, it is the customer_fs.bin with a size of 5 MB by default that is generated, which refers to the 5242880 on the figure.
(3)For customer_backup_fs.bin, it is 200 KB by default, which refer to the 20480 on the figure.
  1. The generated customer_fs.bin file can be seen in the tool directory of mklfs, please check the screen-shot as below.
Method to save parameter
Method to save dynamic parameter
In development, the temporary parameters, variates and string definitions used by developer are called dynamic parameters. As for these parameters, on QuecPython, the GC memory management module is provided to retrieve memory garbage. For more details, please refer to the wiki-related explanation on QuecPython official website: gc - Retrieve memory fragmentations
How to save factory parameter
So how to save factory parameters? there is a need to write the configured factory parameters into file beforehand, then generate .bin file via image. For detailed operation procedure, take the Chapter “The way to generate bin in mass production file” as an example.
File (Script) Backup
Concerning about file backup, there is a necessity to generate a new FW by combining the backup file and the original FW. After that, re-flash it to module. For detailed operation procedure, check the next chapter.
Make image file
For making image file, please refer to the Chapter “The way to generate bin among mass production file”。 Meanwhile, <Quectel_EC100Y-QuecOpen_FS Image Making_Application Note> is also available.
In this document, the image file making of several files are illustrated:
The made image file is
Substitute image file and flash FW
By default, the module will flash a formatted image file with empty contents for the user partition and backup partition, as a result, there is a must to substitute the original image file with customer_backup_fs.bin (The image file after making) so as to generate a new zipped FW. For flashing FW via QPYcom as well as its procedure, please refer to the .
Update file
If you want to flash above files, please login QPYcom beforehand:
The operation shown on interaction surface.
import checksum
checksum.update(‘/usr/a.py’)
[{‘name’: ‘/usr/a.py’, ‘sha256’: ‘454f048b9b584add8b6f67a86ec4ec01ce63baace41efba994881f608a227e30’}, {‘name’: ‘/usr/b.py’, ‘sha256’: ‘3edc1bd333bc7f4caf33bb35e7602bafe5d85c6b6b2ca74a92588a470fbee917’}, {‘name’: ‘/usr/b.txt’, ‘sha256’: ‘cced28c6dc3f99c2396a5eaad732bf6b28142335892b1cd0e6af6cdb53f5ccfa’}, {‘name’: ‘/usr/V05.bin’, ‘sha256’: ‘e5d2dd354947292348a8fb29cdf78e4ffc05754f8e12ecf0dc0ff3783b6b8822’}]
uos.listdir(‘usr/’)
[‘apn_cfg.json’, ‘checksum.json’, ‘a.py’, ‘b.py’, ‘b.txt’, ‘V05.bin’, ‘system_config.json’]
uos.listdir(‘/bak/usr/’)
[‘test.txt’, ‘a.py’, ‘b.py’, ‘b.txt’, ‘V05.bin’]
Operation illustration
(1)The above figure shows the flash after modifying customer_backup_fs.bin.
(2)If it is hoped to update the file under usr directory and run continuously after power on for the next time, there is a need to update checksum.json file via checksum.update interface.
(3)The purpose to backup file is to save the merged file and avoid deleting file by mistake, which cause the failure in retrieve of the program.
