Introduction on Code Encryption
In Python, the pyc file, compiled from py file, is a format of binary. The purpose of which is to accelerate the loading rate on one hand; on other hand, protect original code. The same function is also embedded in MicroPython, which changes the pyc as mpy with its name .mpy appended correspondingly. Above encryption is accomplished by mpy-cross.
Protect py file via mpy-cross
py file
Suffix of python source code file
pyc file
The pyc file, compiled from py file, is a format of binary. The purpose of which is to accelerate the loading rate on one hand; on other hand, protect original code. Meanwhile, the pyc is a kind of byte code that crossing platforms and executed by Python virtual machine.
mpy file
In MircoPython, the .py file can be compiled as .mpy file, which is similar with the .pyc file. Take
user.pyas an example, after encrypting, the file will be changed intouser.mpy. Therefore, we can substitute the originaluser.pyfile withuser.mpy. Please no worry about it for they have the same function.
Encrypt via tool
- Login official website and select “download”, then find “QPYcom Graphical Tool” by selecting the “Resource” in first category and “Tool” in second category comprehensively. Please refer to the figure below.
- After opening QPYcom, tick “Encryption” in “Download”. This function can be used to protect the applicable code of user and make the .py (the source code) into .mpy (the binary code).
Note: The encryption capability of tool will take effect when integrating and producing firmware.
How to encrypt the single file
Compile user.py file in the same directory of tool via mpy-cross-amd64.exe. Please refer to the figure as described below.
Open the cmd line in windows and enter the directory where lies the mpy-cross-amd64.exe. After that, mpy file will be generated via following commands and parameters.
mpy-cross-amd64.exe -mno-unicode user.py
The user.py will be modified as user.mpy after encrypting. Therefore, we can substitute the original user.py file with user.mpy file. In terms of effect, they are just the same.
Read File Protection
System - Environment Configuration
Module Capability: Used to configure parameters and functions of systematical environment.
Adapting Version: EC100Y (V009 and later); EC600S (V002 and later)
system.replSetEnable(flag)
After setting interaction protection, all external commands and codes will be a failure to execute. Since it is an irreversible operation, please confirm before enabling it (It is disabled by default though).
- Parameter
| Parameter | Type | Illustration |
| flag | int | 0: Disabled (By default); 1: Enabled |
Returned value
It returns integer value () successfully.
E. g
import system system.replSetEnable(1) # Enable Interaction Protection
More mpy-cross document
For more details, please refer to the link mpy-cross official document.
