[Document sharing]-Camera Debug
Introduction
Based on quecpthon, this document introduces how to realize camera preview, code scanning and photographing functions through camera module, including interface, configuration process and examples.
At present, quecpython supports two kinds of camera ICs. Subsequent updates will continue
-Bf3901 (8W pixels)
-Gc032a (30W pixels)
The following experiments take gc032a as an example
Schematic analysis
Firstly, the schematic diagram is analyzed to determine the model and pin configuration of camera
Pins: SCK, SDA (IIC pin is used to configure and read the register of sensor)
MCLK: master clock provided to sensor
SPI_ CLK: SPI clock output from sensor to module
Data0: camera SPI data bit 0
Dara1: camera SPI data bit 1
Pwdn: camera off
Camera related interfaces
​ The camera interface mainly refers to the wiki ([camera_api library] on the official website(https://python.quectel.com/wiki/#/en-us/api/QuecPythonClasslib?id=camera-camera-and-code-scan))
Camera configuration development process
LCD initialization (not required)
​ If the preview function is required in this part, the LCD needs to be initialized first.
​ For specific implementation, refer to (LCD instructions
Preview function
​ This part only realizes the preview function of the device.
import camera
preview1 = camera.camPreview(0,640,480,240,320,2)
preview1.open()
preview1.close()
Code scanning function
This part realizes preview and code scanning functions.
def sacn_call(para):
  print(para)
import camera
Scan = camera.camscandecode (0,1640480,2240320) # requires preview function and LCD
# Scan = camera.camscandecode (0,1640480,0) # no preview function is required, i.e. no LCD
scan.open()
scan.start()
scan.callback(sacn_call)
Photographing function
This part of the function realizes the preview and photographing functions.
def cap_call(para):
  print(para)
import camera
cap = camera.camCaputre(0,640,480,0,240,320)
cap.open()
cap.callback(cap_call)
cap.start(240,320,'1')
Appendix a abbreviations of terms
Table 2: Abbreviations of terms
abbreviation 		 Full English name 						 Full Chinese name
LCD  	 Liquid Crystal Display  			 Liquid crystal display
SPI  	 Serial Peripheral Interface  	 Serial peripheral interface
Would this work on a EG916Q-GL?
hi,
Do you need to use EG916Q? Quecpython should not support EG916Q at this time.
I’m currently using both EC200U-EU and EG800Q with an external MCU. I was hoping to attach a camera to one of the Quectel 4G module and hoping this can be done over AT command (snap an image, send to a server maybe through FTP) but I’m not sure if this is available. EG916Q-GL is mentioned because it has camera.
hi
EG916Q does not support Quecpython. If you use the AT command, should you use the standard scheme instead of the Quecpython scheme?
I’m settling down with an EC200UEU.
Do you plan to use Quecython or the standard solution?
Quecython implements functionality through an API, while the standard scheme implements functionality through AT instructions
I have jumped into EC200U to run QuecPython. Quectel told me there’s no plan to support the camera through AT command at the moment.
ok, please refer to the link below for instructions on camera
QuecPython Multimedia - QuecPython (quectel.com)
