This article is mainly based on ec600x_ IIC interface introduces the three-axis acceleration sensor lis2dh12tr, and does a small experiment to detect acceleration.
Hardware introduction
Lis2dh12 introduction
Lis2dh12 is a 3-Axis linear accelerometer with ultra-low power consumption and high performance belonging to “nano” series, with standard output of digital I2C and SPI serial interface. The device has ultra-low power consumption working mode, which can realize advanced energy-saving, intelligent, sleep wake-up and sleep recovery functions. Lis2dh12 has a dynamic user selectable full scale of ± 2G / ± 4G / ± 8g / ± 16g, and can measure acceleration through an output data rate of 1 Hz to 5 kHz. The device can be configured to generate an interrupt signal through independent inertial wake-up / free fall events and through the position of the device itself. The threshold and timing of the interrupt generator can be dynamically set by the end user. Please refer to LIS2DH12.pdf 。
Hardware connection
Pin function introduction:
| Pin number | pin name | description | backup |
| 1 | SCL SPC |
IIC / SPI clock pin | |
| 2 | CS | SPI enable pin, which controls the chip communication mode 1: IIC communication; 2: SPI communication |
| 3 | SDO SA0 |
SPI mode is the data output pin IIC mode is the device slave address selection pin, 1:0x19; 0:0x18。 |
| 4 | SDA SDI SDO |
IIC mode is the data pin data input pin in standard SPI mode it can also be used as the data output pin of SPI |
| 5 | res | grounding is enough | |
| 6 | GND | land | |
| 7 | GND | land | |
| 8 | GND | land | |
| 9 | VDD | power supply | |
| 10 | VDD_ IO | IO reference level pin | |
| 11 | INT2 | interrupt pin 2 | |
| 12 | INT1 | interrupt pin 1 |
In this chapter, we use I2C interface for communication. The schematic diagram is as follows.
This time we d0 / SA0 pin high level. Therefore, it can be confirmed that the slave address of the acceleration sensor is 0x19.
Software design
Lis2sh12 click interrupt usage steps
Functions supported by lis2dh12:
Single click detection
Free fall detection
Inclination angle measurement
Switch horizontal / vertical screen mode
We use the click detection function to map the click event to the INT1 pin. The processing logic is roughly as follows:
Lis2sh12 initialization
- Set Ctrl_ Reg2 register, turn on high pass filtering.
- Set Ctrl_ Reg3 register, which leads the interrupt to the INT1 pin.
- Set Ctrl_ Reg4 register to configure full scale selection
Configure click interrupt
- Configure Click_ CFG register to enable the sensing axis to be detected, x, y, Z
- Configure Click_ Ths register, setting threshold
- Configure time_ Limit register to set the window limit
- Configure time_ Latency register, set delay
Lis2sh12 enable sensor
- Configure Ctrl_ Reg1 register, start enabling the sensor.
Experimental design
- Use the INT1 pin of lis2dh12 sensor to generate an interrupt.
- Poll the status of this pin. After the rising edge is detected, it indicates that an interrupt is generated and the interrupt is processed.
- Read the status of three axes in the interrupt function.
Experimental code
import log
import utime
import _thread
from machine import I2C
from machine import Pin
# Register address
LIS2DH12_OUT_X_L = 0x28
LIS2DH12_OUT_X_H = 0x29
LIS2DH12_OUT_Y_L = 0x2A
LIS2DH12_OUT_Y_H = 0x2B
LIS2DH12_OUT_Z_L = 0x2C
LIS2DH12_OUT_Z_H = 0x2D
LIS2DH12_FIFO_CTRL_REG = 0x2E
# Control register
LIS2DH12_CTRL_REG1 = 0x20
LIS2DH12_CTRL_REG2 = 0x21
LIS2DH12_CTRL_REG3 = 0x22
LIS2DH12_CTRL_REG4 = 0x23
LIS2DH12_CTRL_REG5 = 0x24
LIS2DH12_CTRL_REG6 = 0x25
LIS2DH12_REFERENCE_REG = 0x26
LIS2DH12_STATUS_REG = 0x27
# Status register
LIS2DH12_STATUS_REG_AUX = 0x7
# Interrupt register
LIS2DH12_INT1_CFG = 0x30
LIS2DH12_INT1_SRC = 0x31
LIS2DH12_INT1_THS = 0x32
LIS2DH12_INT1_DURATION = 0x33
# Identity register
LIS2DH12_WHO_AM_I = 0x0F
# Click the relevant register
LIS2DH12_CLICK_CFG = 0x38
LIS2DH12_CLICK_SRC = 0x39
LIS2DH12_CLICK_THS = 0x3A
LIS2DH12_TIME_LIMIT = 0x3B
LIS2DH12_TIME_LATENCY = 0x3C
# Bind it to the external interrupt pin。
class lis2dh12(object):
i2c_dev = None
address = None
int_pin = None
dev_log = None
def init(self, slave_address):
self.dev_log = log.getLogger("I2C")
self.address = slave_address
self.i2c_dev = I2C(I2C.I2C1, I2C.STANDARD_MODE)
self.int_pin = Pin(Pin.GPIO14, Pin.IN, Pin.PULL_PU, 0) # Interrupt pin, which changes according to different hardware connections
self.sensor_init()
self.single_tap_enable() # Configure click detection
self.start_sensor()
pass
def read_data(self, regaddr, datalen, debug=True):
r_data = [0x00 for _ in range(datalen)]
r_data = bytearray(r_data)
reg_addres = bytearray([regaddr])
self.i2c_dev.read(self.address, reg_addres, 1, r_data, datalen, 1)
ret_data = list(r_data)
if debug is True:
self.dev_log.debug(" read 0x{0:02x} from 0x{1:02x}".format(ret_data[0], regaddr))
return ret_data
def write_data(self, regaddr, data, debug=True):
w_data = bytearray([regaddr, data])
# Temporarily put the address to be transmitted in the data bit
self.i2c_dev.write(self.address, bytearray(0x00), 0, bytearray(w_data), len(w_data))
if debug is True:
self.dev_log.debug(" write 0x{0:02x} to 0x{1:02x}".format(data, regaddr))
def sensor_reset(self):
# Reset chip
self.write_data(LIS2DH12_CTRL_REG5, 0x80)
utime.sleep_ms(100)
r_data = self.read_data(LIS2DH12_WHO_AM_I, 1)
# Confirm that the restart is successful
while r_data[0] != 0x33:
utime.sleep_ms(5)
self.dev_log.debug("sensor reset succeeded")
pass
def sensor_init(self):
self.sensor_reset() # 1. Reset the device; 2. Initialize the sensor
self.write_data(LIS2DH12_CTRL_REG2, 0x04) # Enable high resolution
self.write_data(LIS2DH12_CTRL_REG3, 0x80) # Lead the interrupt to the INT1 pin. The default high level is valid
self.write_data(LIS2DH12_CTRL_REG4, 0x08) # ±2g, High-resolution mode
def single_tap_enable(self):
self.write_data(LIS2DH12_CLICK_CFG, 0x15) # Enable XYZ triaxial click interrupt
# self.write_data(LIS2DH12_CLICK_CFG, 0x10) # enables z-axis click interrupt
self.write_data(LIS2DH12_CLICK_THS, 0x30) # Set threshold
self.write_data(LIS2DH12_TIME_LIMIT, 0x18) # Set time window limit
self.write_data(LIS2DH12_TIME_LATENCY, 0x02) # Set delay
def start_sensor(self):
self.write_data(LIS2DH12_CTRL_REG1, 0x77) # Set ODR 400HZ ,enable XYZ
# self.write_data(LIS2DH12_CTRL_REG1, 0x74) # Set ODR ,enable Z axis
utime.sleep_ms(20) # (7/ODR) = 18ms
def read_xyz(self):
data = []
for i in range(6):
r_data = self.read_data(LIS2DH12_OUT_X_L + i, 1)
data.append(r_data[0])
return data
def processing_data(self):
data = self.read_xyz()
self.dev_log.info("xL:{:0>3d},xH:{:0>3d},yL:{:0>3d},yH:{:0>3d},zL:{:0>3d},zH:{:0>3d}".
format(data[0], data[1], data[2], data[3], data[4], data[5]))
self.dev_log.info("X:{:0>3d} Y:{:0>3d} Z:{:0>3d}".
format((data[0] & data[1]), (data[2] & data[3]), (data[4] & data[5])))
pass
def exti_processing_data(self):
value = self.int_pin.read()
if value == 1: # Interrupt signal detected
self.processing_data()
return 1
else:
return 0
# Parameter description
# state: whether to enable interrupt reading. 1: enable; 0: not enabled
# delay: delay time (MS). This parameter is invalid in interrupt mode
# retryCount: number of reads
def is2dh12_thread(state, delay, retryCount):
# | Parameter | parameter type | description |
# | CRITICAL | constant | value of logging level 50 |
# | ERROR | constant | value of logging level 40 |
# | WARNING | constant | value of logging level 30 |
# | INFO | constant | value of logging level 20 |
# | DEBUG | constant | value of logging level 10 |
# | NOTSET | constant | value of logging level 0 |
log.basicConfig(level=log.INFO) # Set log output level
dev = lis2dh12()
dev.init(0x19)
while True:
if state == 1:
if dev.exti_processing_data() == 1:
retryCount -= 1
elif state == 0:
dev.processing_data()
utime.sleep_ms(delay)
retryCount -= 1
if retryCount == 0:
break
print("detection end exit")
if __name__ == "__main__":
_thread.start_new_thread(is2dh12_thread, (0, 1000, 10))
