Settings are below:
We enable GPS and set the value to 7 i.e., GGA, RMC, and GSV.
Also, enable GLONASS and set the value to 7 i.e., GSV, GSA, and GNS.
And set Galileo to 1 i.e., GSV.
We received the below position data.
*$GPGGA,123957.00,1833.294916,N,07347.841190,E,1,06,0.7,605.4,M,-66.0,M,46
$GNGNS,123957.00,1833.294916,N,07347.841190,E,AAA,16,0.7,605.4,-66.0,V*48
Here we observe that position and HDOP are common for GPS and GLONASS.
So, we have some questions:
- We assume the Quetel module uses multiple satellite constellations (GPS, GLONASS and Galileo)
For getting the Lat, Long and HDOP is the assumption correct?
- How do we know the number of the Active satellites used for the Lat, Long and HDOP data calculation?
Weather Quetel send active satellite data in one string? Or do We need to refer to multiple strings to get active satellites?
Which string we should use to get an active satellite?
- Also, do we know if is it the same format for all your products?
