Disable NAT on 5G RM510Q module
Hi everyone,
I’m connecting my RM510Q-GL module to a 5G SA private network, and I’m trying to run a iperf test between 2 notebooks, one of them connected to a SIMCOM module.
The base station is assigning the following IP to the conections:
Quectel module: 192.168.3.2
SIMCOM module: 192.168.4.2
But when I get the ifconfig for the notebook with RM510Q, I’m receiving the following IP:
192.168.225.36
So I can’t run iperf betwen the two machines because one of them is in NAT.
This is the output for the AT command “AT+QETH=“ROUTING”?”:
How can I disable the bridge connection, and get just the IP assigned by the base station?
Thanks,
Luciano
Dear @LUCIANO
Could you check your data call method via AT+QCFG=“usbnet”?
It is recommended to use rmnet or MBIM.
0 RMNET
1 ECM
2 MBIM
3 RNDIS
The command returns an error.
And the command “AT+QCFG=?” returns the following:
It seems that the module does not recognize the usbnet parameter. Maybe it’s outdated firmware?
The command “AT+GMR” returns “RM510QGLAAR11A03M4G”
