Hello Quectel Support,
I have two modems EG800K with different revisions. When I flash my device with one of these two modems, it works perfectly. I am able to configure different settings by AT commands such as AT+CMGF, AT+CSCS and other listed in the manual. The same firmware, though, does not work with a second modem. It only returns OK when sending AT, ATE0 or ATI.
The one working as expected has revision: EG800KEULCR07A07M04.
The one that returns errors whenever I try to change configuration is: EG800KEUCCR07A09M02.
Could you tell me what are the differences between these two revisions and provide me a download link for a firmware of the working revision?
Best regards,
Joanna
Dear Customer,
For your query:
May I know what is the revision for both of your EG800K? If possible, can you give the OC name by check ing on top of the modules or run AT+QGMR
In my observation, it may not because of the firmware issue. Maybe you can try ATE1 command on the second module to enable the echo.
Regards,
Fazrul
Dear Fazrul,
the not working revision is:
EG800K
Revision: EG800KEUCCR07A09M02
the working revision is:
EG800K
Revision:
EG800KEULCR07A07M04
Regards,
Joanna
After further investigation, I know that there is problem with PPP mode. I write messeges and never get back anything. I send as follows these AT commands:
- "AT+CGDCONT=1, “IP”, “internet” - returns OK
- “AT+CGACT=1,1” - returns OK
- “AT+CGPADDR=1” - returns +CGPADDR: 1,“10.199.20.23” and OK
- "AT+CGDATA=“PPP”,1 - returns +CME ERROR: 50
Please provide me a firmware revision EG800KEULCR07A07M04 which I know that configure properly the PPP mode.
Regards,
Joanna
Dear Fazrul,
after further investigation I am almost sure that my firmware version does not support PPP mode.
Could you provide me a firmware version fot EG800K-EU-CC that fully supports PPP?
Best regards,
Joanna
Dear Customer,
I will contact you separately for the firmware.
Sorry for late response.
Regards,
Fazrul Redzuan
I have a similar problem with three EG800K-EUCC modules that apparently don’t support PPP mode (AT+CGDATA=“PPP”,1 returns “+CME ERROR: 50” and “ATD99**1#” doesn’t work either).
The revisions are:
EG800KEUCCR07A06M02_01.001.01.001 (two of them)
and:
EG800KEUCCR07A09M02_01.001.01.001
Can I receive firmware that supports PPP?
Regards
Dear Customer,
I have sent you the latest firmware. Please help to upgrade and feedback.
