Hello
I am trying to figure out the difference between the firmware codes between the EG915Q-NA and the EG915N-EU. As far as I understand it the EG915Q-NA firmware has version codes on the end of: 01.001.01.001 and 01.002.01.002 for version 1 and 2 respectively. When I execute the command AT+QGMR on an EG915N-EU I get the response with the codes at the end being 01.200.01.200. Does this correspond to major version 2? So would the major version 1 would be 01.100.01.100 on the EG915N-EU?
Andrew
Hi,@Andrew4
The changes in these numbers represent alterations on the modem side or the AP side
Hi Leon
Ok I see, could you please send me the update file (.par file) for the EG915NEU so I can go from version 01.200.01.200 to 01.600.01.600. So, this would be from version 2 to 6.
Andrew
Hi,@Andrew4
Could you tell me your current firmware version?
Thanks.
Hi Leon
I get this back when I execute AT+QGMR: EG915NEUAPR03A03M16_01.200.01.200.
So I am guessing that it’s APR03A03M16_01.200.01.200.
Andrew
Hi,@Andrew4
I have sent it to you via email,pls check.
