Difference between e-DRX and e-I-DRX
I’m trying to use the eDRX low-power mode on a BG95-M3. However, while looking through the documentation, I found two different AT command options, and I’m not sure what the difference between them is.
The commands are:
  • AT+CEDRXS
  • AT+QPTWEDRXS
From what I can see, the second command allows you to configure the PTW and eDRX cycle, whereas with the first one you configure something called e-I-DRX.
What’s the difference between e-I-DRX and e-DRX?
BR,
Víctor
They have the same meaning.
