DFOTA ok with HTTP AND ERROR 701 with HTTPS
I am using BG96 module.
I used command and it returns the following value :
==> BG96MBR02A13M1G_01.006.01.006…OK..
AT+QFLDS=“EUFS”
==> CME ERROR: 400
  1. I want to implement an algorithm for the Firmware upgrade with HTTPS server But it seems that my current firmware version does not support EUFS operations, so it cannot store the certificates required for HTTPS, So i tried to flash a new version that supports the HTTPS manually so i installed the driver" Quectel_LTE_5G_Windows_USB_Driver_V2.1" but when i open the peripheral manager i found unknown device (same result when i installed other old versions of drivers from the Forums).
    is there any other solution to make the BG96 support the HTTPS?
  2. And when i used a http server i obtained :
AT+QFOTADL=“http://xx.xx.xx.xx/BG96MBR02A13M1G_01.006.01.006-R02A10M1G_01.003.01.003.bin
+QIND: “FOTA”,“HTTPSTART”.
+QIND: =“FOTA”,"0
+QIND: “FOTA”,“HTTPEND”,702
and it works for the BG95 (http upgrade and downgrade) what can be the problem please?
Hi @issam
Please see attach FILE AN document, to know how to upload certs to module.
