Device not detected on QFlash V4.18
Hi team,
I am currently using BG95M3LA-64-SGNS LPWA Cellular Module for a project of ours.
On the unit, I am unable to see TX lines propagate signals when after having probed the lines.
On another related question, I had seen that this might have to do with the firmware that has been flashed onto the module. When I had connected the device to my PC, I am not seeing the device getting detected for me to flash the latest firmware build. Could you provide any suggestions to my above query?
Hi Linkin,
I have installed the latest version of the application, but I am still unable to see the device getting detected when I try to select the COM port to flash the firmware build.
could you please share you device manager? like this one.
А какой драйвер нужен?
