CTS and RTS in EC25
the hardware flow control CTS and RTS in UART interface, is enabled in default condition? If no, how can I enable it?
My module is:
EC25 EUX
Revision: EC25EUXGAR08A08M1G
Query current setting with AT+IFC?
Set syntax:
AT+IFC=<dce_by_dte>,<dte_by_dce>
Parameter values:
<dce_by_dte> Specifies the method that will be used by TE when receiving data from TA
0 None
2 RTS flow control
<dte_by_dce> Specifies the method that will be used by TA when receiving data from TE
0 None
2 CTS flow control
Thanks snowgum,
In the AT command manual, the command AT+IFC refer to behavior of the serial port for “data mode” and not at-command mode.
The following command activates the CTS-RTS for at-command mode also?
AT+IFC= 2,2
Cosider that I don’t use the “data mode”. I’d like to use the CMUX (all the four virtual com) for AT-Commad and for this I’d like to activate the CTS-RTS flow control.
You might need to compile a C program to test the effect in command mode. I found this:
https://www.linuxquestions.org/questions/programming-9/manually-controlling-rts-cts-326590/
