Connecting to server by MQTT and TSL. Information about phases for connection
Hi, people. I get “+QMTOPEN: 0,-1” from server when trying to open. Can i get more information about errors. Can i, for example, get information about - server accepted certificate or not.
My log below. what must i send questions to server owner best? what is directions for this.
AT
ATI
Quectel_Ltd
Quectel_M08R
Revision: M08RMAR01A03
AT+QMTCFG=“VERSION”,0,1
AT+QMTCFG=“SSL”,0,1,2
AT+QSECWRITE=“RAM:cacert.pem”,1360,100
CONNECT
AT
ATI
Quectel_Ltd
Quectel_M08R
CONNECT
+QSECWRITE: 1360,4a48
AT+QSECWRITE=“RAM:client.pem”,1809,100
CONNECT
+CPIN: READY
+QSECWRITE: 1809,1643
AT+QSECWRITE=“RAM:userkey.pem”,1729,100
CONNECT
Call Ready
SMS Ready
+QSECWRITE: 1729,647a
AT+QSSLCFG=“cacert”,2,“RAM:cacert.pem”
AT+QSSLCFG=“clientcert”,2,“RAM:client.pem”
AT+QSSLCFG=“clientkey”,2,“RAM:userkey.pem”
AT+QSSLCFG=“seclevel”,2,1
AT+QSSLCFG=“sslversion”,2,3
AT+QSSLCFG=“ignorertctime”,1
AT+QMTOPEN=0,“name.server.net”,8000
+QMTOPEN: 0,-1
… repeated
Hi,You will need to provide the local ip address of your device to the server owner, who will help you check whether your device has been successfully registered with the server
Also, it’s best to provide your connection time
Tnx bro for help, but it was wrong cipher suit..
You mean you used the wrong password? However, you need to confirm the server password from the person in charge of the server, and then confirm it in “AT+QSSLCFG”
cipher suite - it isn’t password. read datasheet, please.
You may have a lot of errors, certificate path may be wrong, certificate path may be wrong, the process of connecting to the server may be wrong, specifically you need to catch a core log for analysis, and “name.server.net” the website I suggest you can change to use the ip domain name + port connection
