I have several EM120R_GL that I’m trying to work with but the hardest part is getting an antenna connected. I can’t find any type of adapter that will work. Is there any way to connect an antenna to this? I can see on the board there are two connection points but they don’t work with an uFL I have tried. I hired some help to suggest products that would work with this and none of them do.
I can’t believe there’s any way this can receive a GPS signal without an external antenna, and Quectel did include two antenna connection points, but there’s no hardware I can find that will actually attach them. If Digikey sells any part that can connect to this please let me know. Alternatively, if I need to switch to a different model that allows an antenna, let me know what to get. Thank you
