I’m facing an issue while trying to connect two RM520-GL that I have installed on the same machine. One is PCI and the other is USB, I wrote a systemd service to each one of them based on quectel-CM tool.
Both of the cards get connected but only one of them has a default route on the route table. The problem starts if the card that has the default route drops, and then I lose the connection cause I don’t have a default route to the other card…
I was wondering if you have a solution to that problem.
Thank you for your support.
We found a solution by managing the routing table with a script we wrote.
Something interesting we found is that you can declare the default gateway of the RM520 as the IP address it gets from the carrier.
Even though, when the quectel-CM does it, it sets a different IP address (usually +1 or -1 from the IP the carrier provides).
