My university tutor received a SIM card (Vodafone) from Quectel a few days ago and I now want to use the BC660K-GL module to connect to Quectel IoT Portal. According to the instructions in the documentation center, I should use AT+QIOTREG=1 to open the module’s QuecThing function, but there is an error,maybe my BC660K-GL module does not have QuecThing function,what should I do ?
Oh sorry, your current BC660K model does not support the QuecThing AT command set, requires a specific module model, if you must connect to QuecThing, you need to buy a specific model; If you are only verifying the application protocol, I recommend signing up for AWS, which is commonly used by our overseas users
Do you mean that I can’t connect to Quectel IoT Portal in Germany with the BC660K-GL module?
But according to the information I got, it is possible to connect to Quectel IoT Portal without using the QuecThing AT command set.
Follow the instructions on the platform and connect using the standard at command set to QuecThing
