This is kaavya ,
Am using Quectel M66 module .
i just want to connect it with my google firebase account through url using AT-commands .
Can anyone please send me the required command list and also steps how to add those command .
And also which all commands used to send and receive data from the firebase .
Really needed help …please respond asap.
Dear Sir,
About your requirment, it is better to check the following GSM HTTP(s) at command or application note, which already give you the example command sequence for reference.Please check. Thanks! Quectel_GSM_HTTP_AT_Commands_Manual_V1.4.pdf (314.6 KB) Quectel_GSM_HTTPS_Application_Note_V3.2.pdf (909.3 KB)
