Connect LC29H (BS) to SkyBrush Software
Hello, I need to connect my LC29H (BS) module to the Skybrush software, which has the following requirements:
RTCM3/1077 (GPS corrections MSM7): at least once per second
RTCM3/1087 (GLONASS corrections MSM7): at least once per second
RTCM3/1006, 1008, or 1033 (antenna position): at least once every ten seconds
In addition to GPS and GLONASS corrections, you may also want to enable corrections for BeiDou (RTCM3/1127), Galileo (RTCM3/1097), or QZSS (RTCM3/1117), depending on the area you are operating in. Some RTK GPS modules do not understand MSM7 messages; in that case, try MSM4 corrections (RTCM3/1074, 1084, 1094, 1114, and 1124 for GPS, GLONASS, Galileo, QZSS, and BeiDou, respectively).
If someone could please help me, thank you very much (I might tip for the help).
Hi Customer
  1. LC29H(BS) only supports 1005 but not 1006.
  2. RTCM messages are output once per second, and changing the output frequency is not supported.
  3. Please refer to the “Quectel_LC29H(BS)_GNSS_Protocol_Specification_V1.1.pdf” document. The document is sent to you via email.
Hi! can you send me the last firmware? please
Hi @Mcelis
I have sent you the relevant information via email, please check.
