Hello guys I am trying to sends commands to an lc29h gps module. It works when i use the QCOM v1.6 provided by qectel, but when i am trying to send a command using tera term or puty I receive no response. I want to mention that the setial port is configured correctly. The photo is a dev board. Has anyone encountered this issue?
Bellow is a picture of the dev board i am using
Hi Ben Dover,
Did you receive constant NMEA message from tera term/puty after connect to the EVB?
Did you disconnect QCOM tool before using tera term/puty?
Best regards.
hi, yup i get constant nmea messages from the board and i disconnected the qcom tool
