Hi! Can you drop me an email for the command datasheet for RG500Q-EA. Thanks in advance.
Dear @SolomonRicky
Sorry for the late.
I have sent it to you via Message, please check.
Hi @silvia thanks for replying. Now I have another issue can you take a look?
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.020728] ------------[ cut here ]------------
Sat Nov 18 22:03:04 2023 kern.info kernel: [ 5930.020765] NETDEV WATCHDOG: wwan0 (cdc_mbim): transmit queue 0 timed out
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.024439] WARNING: CPU: 3 PID: 0 at dev_watchdog+0x240/0x250
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.031100] Modules linked in: qcserial pppoe ppp_async option cdc_mbim ath11k_ahb ath11k usb_wwan qmi_wwan pppox ppp_generic mac80211 ipt_REJECT cfg80211 cdc_ncm cdc_ether xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_socket xt_recent xt_quota xt_pkttype xt_owner xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_iprange xt_hl xt_helper xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_cgroup xt_addrtype xt_TPROXY xt_TCPMSS xt_REDIRECT xt_PROTO xt_NETMAP xt_MASQUERADE xt_LOG xt_HL xt_DSCP xt_CLASSIFY usbserial usbnet ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda spi_gpio spi_bitbang slhc qrtr_smd qrtr qmi_helpers nf_tproxy_ipv6 nf_tproxy_ipv4 nf_socket_ipv6 nf_socket_ipv4 nf_reject_ipv4 nf_log_syslog nf_conntrack_netlink nf_conncount iptable_nat iptable_mangle iptable_filter ipt_ECN ip_tables gpio_74x164 crc_ccitt compat cdc_wdm ntfs3 xt_set ip_set_list_set
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.031258] ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ipmac ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 ip6t_NPT ip6t_rt ip6t_mh ip6t_ipv6header ip6t_hbh ip6t_frag ip6t_eui64 ip6t_ah ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 sit tunnel4 ip_tunnel udp_diag tcp_diag raw_diag inet_diag tun nls_utf8 nls_iso8859_1 nls_cp437 sha512_generic seqiv jitterentropy_rng drbg michael_mic hmac cmac uas usb_storage leds_gpio xhci_plat_hcd xhci_pci xhci_hcd dwc3 dwc3_qcom qca_nss_dp qca_ssdk gpio_button_hotplug vfat fat ext4 mbcache jbd2 exfat aquantia hwmon mii crc32c_generic
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.176749] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 6.1.60 #0
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.198982] Hardware name: Arcadyan AW1000 (DT)
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.204709] pstate: 80400005 (Nzcv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.209226] pc : dev_watchdog+0x240/0x250
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.216165] lr : dev_watchdog+0x240/0x250
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.220331] sp : ffffffc008c63e20
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.224325] x29: ffffffc008c63e20 x28: ffffffc008c3e000 x27: ffffffc008c63f00
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.227630] x26: 00000000000000e0 x25: ffffffc008c3e620 x24: 00000000000000a0
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.234748] x23: 0000000000000000 x22: ffffffc008b36000 x21: 0000000000000000
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.241867] x20: ffffff8002211000 x19: ffffff8002211478 x18: 00000000000001bc
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.248985] x17: ffffffc037384000 x16: ffffffc008c60000 x15: ffffffc008b47218
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.256103] x14: 0000000000000534 x13: 00000000000001bc x12: 00000000ffffffea
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.263220] x11: 00000000ffffefff x10: ffffffc008b9f218 x9 : ffffffc008b471c0
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.270339] x8 : 0000000000017fe8 x7 : c0000000ffffefff x6 : 0000000000000001
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.277457] x5 : ffffff803fdd9708 x4 : 0000000000000000 x3 : 0000000000000027
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.284574] x2 : 0000000000000027 x1 : 0000000000000023 x0 : 000000000000003d
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.291694] Call trace:
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.298802] dev_watchdog+0x240/0x250
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.301061] call_timer_fn.constprop.0+0x24/0x80
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.304881] __run_timers.part.0+0x238/0x284
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.309568] run_timer_softirq+0x3c/0x74
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.313822] _stext+0x10c/0x290
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.317726] ____do_softirq+0x10/0x20
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.320591] call_on_irq_stack+0x24/0x50
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.324412] do_softirq_own_stack+0x1c/0x30
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.328405] __irq_exit_rcu+0xc4/0xf0
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.332310] irq_exit_rcu+0x10/0x20
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.336129] el1_interrupt+0x38/0x5c
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.339428] el1h_64_irq_handler+0x18/0x2c
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.343248] el1h_64_irq+0x68/0x6c
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.347154] arch_cpu_idle+0x18/0x2c
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.350540] default_idle_call+0x30/0x74
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.354273] do_idle+0x228/0x250
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.358178] cpu_startup_entry+0x38/0x40
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.361392] arch_show_interrupts+0x0/0x16c
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.365297] __secondary_switched+0xb0/0xb4
Sat Nov 18 22:03:04 2023 kern.warn kernel: [ 5930.369204] ---[ end trace 0000000000000000 ]---
Sat Nov 18 22:03:09 2023 kern.warn kernel: [ 5935.860812] xhci-hcd xhci-hcd.2.auto: xHCI host not responding to stop endpoint command
Sat Nov 18 22:03:09 2023 kern.err kernel: [ 5935.891101] xhci-hcd xhci-hcd.2.auto: xHCI host controller not responding, assume dead
Sat Nov 18 22:03:09 2023 kern.err kernel: [ 5935.891179] xhci-hcd xhci-hcd.2.auto: HC died; cleaning up
Sat Nov 18 22:03:09 2023 kern.info kernel: [ 5935.899258] usb 4-1: USB disconnect, device number 2
Sat Nov 18 22:03:09 2023 kern.info kernel: [ 5935.903638] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Sat Nov 18 22:03:09 2023 kern.info kernel: [ 5935.908645] option 4-1:1.0: device disconnected
Sat Nov 18 22:03:09 2023 kern.info kernel: [ 5935.916663] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Sat Nov 18 22:03:09 2023 kern.info kernel: [ 5935.920878] option 4-1:1.1: device disconnected
Sat Nov 18 22:03:09 2023 kern.info kernel: [ 5935.929082] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Sat Nov 18 22:03:09 2023 kern.info kernel: [ 5935.933398] option 4-1:1.2: device disconnected
Sat Nov 18 22:03:09 2023 kern.info kernel: [ 5935.941590] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
Sat Nov 18 22:03:09 2023 kern.info kernel: [ 5935.945881] option 4-1:1.3: device disconnected
FYI, I using
Module: Quectel RG500Q_EA
Firmware: RG500QEAAAR11A07M4G_ACY
Operating System: OpenWrt Snapshot
Kernel: 6.1.60
Device: Telstra Arcadyan AW1000
Protocol: QMI/MBIM/ECM (All having the same issue)
