I’m using usb ports 2 and 3 for communicating with my EG25
Port 2 is used only for commands and reposnes (including URC)
Port 3 is only used for data connections.
I’m setting my SMS notification parameters as below and it works as expected. I get the full SMS notification with the full PDU.
AT+CNMI=1,2,2,1,0
Once I go into data mode on port 3 I no longer get the +CMT URC but instead get the +CNMI notification with the index (sometimes -1) that a notification is received.
After I shut down the data connection there is no change to this behavior and a query to AT+CNMI?
results in +CNMI: 2,1,0,0,0.
Is there a way that I can prevent this change in behavior?
Many thanks,
Ken
PPP startupScript
TIMEOUT 60
ABORT “BUSY”
ABORT “VOICE”
ABORT “DELAYED”
ABORT “ERROR”
ABORT “NO DIALTONE”
ABORT “NO CARRIER”
ABORT “NO ANSWER”
‘’ ATZ
OK ATE0
OK ATI;+CSUB;+CSQ;+COPS?;+CGREG?;&D2
OK AT+CGDCONT=1,“IP”,“Broadband”
OK ATD*99#
CONNECT ‘’
After Data Shutdown
ATI
EG25
Revision: EG25GGBR07A08M2G
AT+CNMI?
+CNMI: 2,1,0,0,0
