Clear Stored Network Information
I am trying to perform testing of the initial registration process because I am seeing long initial registration times. My development kit has stored the network information so now it connects quickly, which is the desired normal use case. However, I would like to clear the network information so that I can perform testing. Is there a command or procedure for clearing this information from the BG95?
Hi @William_Brown
You can clear historcial infos with following commands:
GSM: AT+QNVFD=“NV/item_files/modem/geran/grr/acq_db”
LTE : AT+QNVFD=“/nv/reg_files/modem/lte/rrc/csp/acq_db”
NBIoT: AT+QNVFD=“/nv/reg_files/modem/nb1/rrc/csp/acq_db” Note: Hardware reset
Clear LOCI(RPLMN): AT+CRSM =214,28542,0,0,11,“FFFFFFFFFFFFFFFFFFFFFF”
Clear PSLOCI: AT+CRSM =214,28531,0,0,14,“FFFFFFFFFFFFFFFFFFFFFFFFFFFF”
Clear PSLOCI: AT+CRSM=214,28643,0,0,18,“FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF”
Thank you for the feedback. All of the QNVFD commands appear to run correctly, but I am getting errors with the CRSM commands. Here is my serial data.
[2024-07-08_08:37:02:461]AT+QNVFD="NV/item_files/modem/geran/grr/acq_db"
[2024-07-08_08:37:02:461]OK
[2024-07-08_08:37:04:216]AT+QNVFD="/nv/reg_files/modem/lte/rrc/csp/acq_db"
[2024-07-08_08:37:04:216]OK
[2024-07-08_08:37:04:980]AT+QNVFD="/nv/reg_files/modem/nb1/rrc/csp/acq_db"
[2024-07-08_08:37:04:980]OK
[2024-07-08_08:37:06:780]AT+CRSM=214,28542,0,0,11,"FFFFFFFFFFFFFFFFFFFFFF"
[2024-07-08_08:37:06:780]+CME ERROR: 23
[2024-07-08_08:37:08:851]AT+CRSM=214,28531,0,0,14,"FFFFFFFFFFFFFFFFFFFFFFFFFFFF"
[2024-07-08_08:37:08:851]+CME ERROR: 23
[2024-07-08_08:37:09:487]AT+CRSM=214,28643,0,0,18,"FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF"
[2024-07-08_08:37:09:487]+CME ERROR: 23
Do you have any sugguestions?
Are you insert SIM or without SIM to send those commands? BTW, which fw version are you using now? (AT+QGMR)
