Check firmware revision in RM500Q-GL
I’m working with an RM500Q-GL modem and I need to check not only the firmware version but also the firmware revision using AT commands. For example, we have the next FW versions:
  • RM500QGLABR13A03M4G_01.203.01.203
  • RM500QGLABR13A03M4G_01.204.01.204
I can retrieve the version (RM500QGLABR13A03M4G) with commands like ATI or AT+GMR, but I haven’t found any documented way to obtain the specific firmware revision (01.203.01.203 / 01.204.01.204).
Is there an AT command (standard or vendor-specific) that provides the firmware revision on the RM500Q-GL, or is there any alternative method outside the AT command set to obtain it?
Thank you so much.
Dear @aj.rodriguez
Could you please send me the latest firmware for RM500Q-GL,thanks a lot! Email: andyhe80@gmail.com
Dear @andyhe80
need latest firmware for rm500q-gl too
Dear @ritech
hi
current firmware
RM500QGLABR13A03M4G_01.202.01.202
Dear @ritech
