Hi.
I am thinking of changing the firmware version by using AT+QFOTADL.
I would like to request required files that will be used to change the version.
Current firmware version
BG96MAR02A10M1G_01.013.01.013
change version to
BG96MAR02A07M1G_01.017.01.017
I would appreciate it if you could let me know whether you can accommodate my request. Your expert advice and support will be invaluable to the project’s success, and I eagerly await your reply.
Yours sincerely,
Hi
Are you sure to downgrade to BG96MAR02A07M1G_01.017.01.017 ?
Its ok for you to downgrade to use QFLASH tool? it will take a many days to apply a fota packet.
I understand that it might take a few days, Would it be possible for you to send me
FW files listed down below?
Current FW version
I would like to update FW version to
BG96MAR03A08M1G_01.001.01.001
Hi @Nakamura
There is no R03A08M1G01.001.01.001, Is ok for you to send BG96MAR03A09M1G_01.001.01.001 ?
Hi.
Yes, I’d appreciate it if you could send me the BG96MAR03A09M1G_01.001.01.001
version along with the QFLASH tool so it can be used to flash firmware onto device.
Your earliest response would be highly appreciated.
Hi @Nakamura
Here is FW : BG96MAR03A09M1G_01.002.01.002 latest then 01.001
QFLASH Tool:
