Change FW version EG06-a to version EG06-E
Is it possible to change region on this EG06-A firmware?
Need firmware for EG06-E
Hi kragena,
No, the region cannot be changed by firmware. EG06-A and EG06-E are separate product variants with their own band configuration and their own firmware packages, and the firmware is bound to the variant. Writing the EG06-E package into an EG06-A module fails the product check on the download path, and if it goes through partially the module can end up in a state that needs recovery.
To move to EG06-E, please use an EG06-E module. For firmware for a specific variant, contact your distributor or our support team with the module variant, the OC or marking, and the IMEI, so the package that matches your module can be provided.
Thank you and have a nice day!
