Certifications for the EG916Q
we are currently developing a device based around the EG916Q-GL Module. In the Standard Specification Sheet it´s stated that the certifications regarding the regulatory is still in development or in progress.
We want to start the certification process for our device soon, so we wanted to ask when the regulation certification for the EG916Q-GL is finished or what the current state of the process is.
We are particularly interested in the certification for the IC and FCC and if you could provide the associated letter of approval we would be very thankful.
Thank you in advance.
hello, i have sent the certificate documents in you email, please check it, thanks~
Thanks for providing the documents.
Can you also provide me with the detailed tests reports of the measurements.
Those are needed for comparison measurements in our certification process.
hello,please check the document in your mailbox. These documents can also be obtained from your supplier, which will be more convenient for you, thank you :grinning:
Hi we are also planning to use EG916Q, can you send me certificates for North American market at my email if. pl surajdsp@gmail.com
Would it be possible to get access to those certification as I will enter the process of certification for CE and FCC?
