Cell Scan on EG912N-EN
Hi there,
is there an AT-Command for searching cells? On the BG95-M4 there is the great AT-QCOPS command for searching cells unattached. Is there a similar command for EG-Modems? If not, please consider adding it to the firmware.
Thanks in advanced!
Hi @gernotohnenot
AT+QCELL is the equivalent on EG912N-EN. It returns the serving cell plus intra-frequency and inter-frequency neighbour cells, with MCC, MNC, TAC, cell ID, PCI and RX level, and it works with no SIM inserted.
AT+QCELL?
+QCELL: "servingcell","LTE",460,00,550b,d6b5c0,123,36
+QCELL: "neighbourcell inter","LTE",460,00,550b,5e05e2a,20,12
Hi AmarRaaj,
thanks for the quick reply! I tried AT+QCELL? on the EG912N-EN (firmware 01.303, LTE band 72), both with and without SIM. Unfortunately it only ever returns the serving cell plus one intra-frequency neighbour, the same two cells in every query. There is no EARFCN, and no inter-frequency cells show up at all. It also answers in under a second, so it looks like it only reports what the module already knows about its current cell. It doesn’t seem to actually scan.
AT+QENG=“neighbourcell” shows a lot more (around 15 cells on two EARFCNs within a minute), but without cell IDs. So it’s not really what AT+QCOPS does on the BG95-M4, which gives us all cells with EARFCN, PCI, cell ID and signal levels in one go.
Is there any other way to get a real cell scan on the EG912N-EN, maybe a newer firmware or an undocumented command? If not, it would be great if you could consider adding something like QCOPS.
Thanks again!
